This is a discussion on Full built KA-T setup...turbo, engine, etc. within the Buy and Sell Area forums, part of the Classifieds category; KA-T setup for sale: I'm located in Baltimore, Md. I WILL ship, but it will be expensive ($3-500ish) and tacked ...
I'm located in Baltimore, Md. I WILL ship, but it will be expensive ($3-500ish) and tacked onto the sale price. I hate to sell it, i've put sooooo much into it. The engine has been nothing but absolutely reliable, but I need money, and have a lot of obligations. I will edit the post later if the clutch is also available with the setup. The clutch is a competition 7.5" twin plate with flywheel. The clutch retails for $1400, and is garaunteed to hold 800ish whp. This clutch is AMAZING. Clutch and flywheel combined only weigh 19.5lbs. (factory flywheel weighs 24ish lbs. alone) I would rather sell this as a whole, but I will part for the right $$. Comes with a factory transmission Motor has under 10k miles on it, oil changed every other event (motul full synthetic). Compression just checked @ 155psi +/- 3psi across the board. Turbo has under 500 miles on it Clutch has under 500 miles on it Here's the mod list: MA-Motorsports built engine - Wiseco forged pistons 8.5:1 CR, .020" oversized - Balanced crank - 3 angle valve job - fully rebuilt head - OEM bearings - Nissan Gasket set - ARP head studs - Oil pan modified for 5/8" oil return - Custom fitting welded for turbo water coolant supply Crank pully has 6" 60-2 toothed wheel for Electrmotive ignition system, or full stand alone. Should work with any stand alone compatible with hall effect setup. The distributor hole has been plugged with a freeze plug (can be removed to retrofit a distributor) GT3076R nicknamed GT30R, T3 non-GT 4bolt exhaust housing, .63 a/r, 4" shroud ported inlet (full spool around 3-3200rpms) Turbo comes plumbed in with oil and and water. Precision 780cc p/min fuel injectors Custom Top feed fuel rail, -8 AN male fitting on back side, -6 on the front side -6 AN line to connect feed or return on fuel rail to the stock filter (w/ a barbed to -6 adapter) or an adjustable FPR Totally stripped down of all factory crap (no EGT, no IACV, no vacuum bizzareness) Greddy VSPL intercooler custom mounted upside down under the core support comes w/ brackets. custom intercooler piping to mate turbo to IC and IC to throttle body, all Tbolt clamps Tanabe transmission bushing kit. Oil filter sandwitch with integrated thermostat, has -8 AN fittings welded for an oil cooler, or whatever you want. MA-Motorsports log manifold MA-Motorsports down pipe 38mm Tial knock off waste gate (1bar/14.7psi spring) with spare diaphragm 5 zigen 80mm rocket Exhuast to mount to S13 and downpipe (no cat) K2rd stainless steel clutch line With this seutp, when I went to the dragstrip to tune, I ran a 12.7 @ 118mph with a 2.7 60ft. I grannied it through the first 2 gears like I was taking off from a stop light next to a cop with a car made of cocaine. So needless to say I was shifting around 3000rpms, and not on the throttle untill low 3rd gear, then i'd mash the throttle. Video of the car in action w/ 265 rear tires: Thanks to Gary for the video!! http://mattmartindrift.com/Video/public_vi...8_2006_Matt.wmv with old turbo: ![]() with GT30R ![]() ![]() ![]() I'm asking $4000 OBO; or $5000 (with clutch) for ALLLLL of it. Questions or offers: Email: matt(at)mattmartindrift.com Last edited by mattmartindrift; 10-31-2006 at 10:44 PM. Reason: pistons listed as 9.5:1, they are actually 8.5:1 (typo) |
Pistons are 8.5:1, NOT 9.5:1 as the typo may have previously said
Okay, buyer flaked on me, so i'm bumping this post.
The clutch IS for sale too! Remember this is OBO |
Is it still for sale. and if so, can i come look at it.
Hey I just wanted to know if the car is still for sale?
Okay, I give up, I'm parting this setup out, make me offers!!!!!
Clutch is sold, I still have: Complete engine Manifolds GT30R turbo kit for KA (piping, FMIC, manifold, DP, wastegate, etc.) 780cc/min precision injectors (top-feed) Custom fuel rail w/ -6/-8 AN fittings welded on Koyo Radiator for KA Transmission Basically anything in the engine bay you want/need except for the ECU |
