This is a discussion on FS: 1989 RMJ 240sx Fully Built Drift Car within the Buy and Sell Area forums, part of the Classifieds category; This is a race car and has no smog and is not smog legal in California, we are selling this ...
This is a race car and has no smog and is not smog legal in California, we are selling this car as is and will not be responsible for smog.
![]() Last Dyno was on 2-10-2008, car made 302whp at 13.5 psi All work and maintenance done strictly by RMJ. Tuning by Illicit Performance, Machine work by Indio Motor and Machine Sr20DET -Balanced and micropolished crankshaft -Cryo treated stock rods -MAHLE pistons & Rings (8.5.1 compression) (86.5mm bore) -Head Port and Polished by Illicit Performance -Cometic Head Gasket -Jim Wolf Valve guides -OEM Nissan Valve Seals -Head hot tanked, pressure checked, and valve job done (Indio Motor and Machine) -Brian Crower Valve springs and retainers -Brian Crower 264 Cams -Engine has gotten an oil change before every event, 10-40 Neo Synthetic -Engine was built end of 2006 and ran in the 2007 Top Drift Series -Head is new and built in January 2008 Turbo Performance Built: T3/T4 Turbo .70ar Hot Side Turbo Performance Intercooler Intercooler and Exhaust Piping Custom Taka Motorsports Oil Feed Lines GReddy Type R Blow off Valve Engine Management: Haltech E6X -LS1 Coil ignition -3-bar Map sensor -Tuned by Illicit Performance 650cc Fuel Injectors NISMO Fuel Pressure Regulator Rotary Performance, Denso Racing intake Fuel Pump Stock SR20 Transmission, serviced with only Neo Synthetic Oil every two events KAAZ 2-way LSD, serviced with NEO Synthetic Oil after every event. Water pump is 1 year old KOYO Radiator 2 years old New Nissan Thermostat (installed 2-20-08) -Engine has only been ran on Distilled Water and NEO Synthetic Keep Cool Stock Crank Fan 17" Electric Fan B&M Oil Cooler with Taka Motorsports Oil Filter Relocation kit and lines Chassis/Suspension -TEIN HE Coilovers (no leaks, work great) -Battle Version Front Tension Rods -TEIN Tie Rods and Ends -Rack and Pinion 2-years old -Battle Version Rear upper control arms -Urethane Sway bar end links -Tanabe front sway bar -Wrong Way SPL 6-point cage (PRO AM Legal) Built by Henry Schelley INterior -GReddy 52mm Oil Pressure Gauge -GReddy 52mm Boost Gauge -GReddy 60mm Warning Water Temp Gauge -GReddy 60mm Warning EGT Gauge -GReddy Turbo Timer -Apex AVC-R Boost Controller -Sparco Bucket w/Bride Seat Rails (drivers, passenger seat is stock) -Momo Steering wheel -Interior is stripped -Battery relocated to rear, behind passenger seat Exterior -VIS Hood -Type X Tails lights and garnish (with key and lock, installed brand new 3 years ago, no damage) -30mm Rear Fenders -Nismo Front -Vertex Replica Side Skirts -Type X wing -Four Falken Hannabi wheels 17x9 20offset -Brakes: (installed mid 2007) Front Project Mu Titan Kai Pads w/ Power Slot Rotors Rear: Stock Rotors with Hawk HP Plus Pads Car runs Solid and has a lot of history and references, just ask around the JustDrift and Drift Day community. Just finished a strong performance in Top Drift Round 1. Has finished top 8 in Top Drift in 2007, performed at the Pro AM Nationals in November 2007. We are selling the car because we are focusing on our drivers 240sx coupe. These are all current photos and the video is from the last event on 2-24-08 If you have any questions or want to see the car, please feel free to contact me. $14,000 Miguel - RMJ Motorsports 805-340-6353 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Video: http://rmjmotorsports.com/gallery/Im...d1_2008rmj.wmv |
so many views, but no interest? for those that want a legit Pro-AM competition car, this is it.
