This is a discussion on IN 1989 240sx Track Ready Neukin Vmount and Cage KAT within the Buy and Sell Area forums, part of the Classifieds category; Hey guys, need to get rid of this for the winter, will be working on another project. $9900 Good clear ...
Thread Tools |
Rating:
Display Modes |
$9900 Good clear title plated and insured VIN= email me. Welded 6Point+ Neukin Race Roll Cage with harness bar, diagonal, strut bar in rear between the two bars that connect to hoop. dual door bars on both sides, drivers side has two vertical bars on the door bars. the front two points are up to the frame and go through the dash. The top bar near roof is a upper hoop. All kinda painted cream.. free over spray on dash. FOR LARGER PICTURES GO HERE ----> http://www.neukin.com/Articles.asp?ID=133 Megan Racing 32-way "Track" Coliovers with front camber plates/pillow ball upper mounts all around Front Coilovers bottom hole slotted for more camber (running 3d in front able to hit 5d+) Megan Front Roll Center Adjuster Megan front steering S13 Rack Ends add more steering angle Megan Engine / trans Mounts - much stiffer Megan Tie Rod Ends Megan Front Pillow Tension Rods Megan Rear Lower Toe Arms Megan Rear Lower Traction Rods Megan Rear Upper Control Arms Rusell stainless brake lines Kaaz 2way LSD and fluid Steel one piece driveshaft Hawk HP plus pads and brand new rotors all around 5lug conversion obd2 96 S14 motor/ecu/trans Neukin vmount kit -large Neukin intercooler for 650hp -huge double pass radiator and mounting system -silicone couplers and stainless Tbolts -Stock hood lightened and louvered perfect for the intercooler core. Neukin bottom mount manifold Neukin power steering relocation Neukin 3" downpipe Neukin Mid Pipe 3" stainless exhaust system NRG short hub, quick release wheel 2.5 and "Race" leather wheel w red stitch BM short shifter kit and killer aluminum knob One set of SportMax 17x8 with fuzion zRi for daily or running to a event brand new One set of Motegi Traklites 17x8 (only 15lbs each!) with R888 Toyos with half tread ARP wheel studs all around Muteki blk open wheel lugs and key Walbro 255 intake Top feed fuel rail Dual 10" E Fans 6 switch bank (used right now pump, fan 1, fan 2) Two main switch near cluster (ign, and start) Key for both doors, not used for start Clear title and steetable (just ran to MidOhio last weekend for a track day - drove it there) No performance injectors or ecu, replaced with stock injectors and Synapse FPR/fmu for 6psi KA-T Synapse 50mm Wastegate Synapse synchronic BOV Vac lines are push on and stand 500 degrees F brake master cylinder shield for the safe side Odyssey PC680 battery (8 pounds!) New slave and master for the clutch, new hardline and stainless flex line. New 6 puck clutch and 100ftlbs more pressure plate but it slips at like 4 psi so that needs replaced.. again Was a automatic so the chassis was setup and 5speed setup installed with correct pedals ect so you cant really tell but thought id toss that out there. THE LACK OF RUST IS GREAT Sparco seat and G Force 5 point harness/cam lock Brand new alternator parts not installed, N62 MAF, Megan racing subframe collars, S14 cluster,
Hey, i put the S13 sexy pig nose on ebay with no RESERVE... right NOW.
$5000+ You can check out larger pics at the new link below. Plus there is new parts on it and such so the above parts list and info is out of date. Custom Aluminum neukin exhaust saved 20 lbs plus you get the old stainless one two sets of wheels and more FOR LARGER PICTURES GO HERE ----> http://www.neukin.com/Articles.asp?ID=136 |
Do you have a link to the eBay listing?
