This is a discussion on FS: engine, clutch gauges, down pipe, engine harnesses and more within the Buy and Sell Area forums, part of the Classifieds category; stock sr20det oil pan- 30 used act 6 puck clutch with alot of life on it- 150 3 inch cat ...
used act 6 puck clutch with alot of life on it- 150 3 inch cat delete pipe- 50 s14 ka fan shroud- 40 sohc mafs-30 z32 MAFS plug- 20 sr20det downpipe new- 60 s14 rear strut tower bar- 30 s13 sr20det engine harness with cut mafs plug and injector plugs- 160 s13 sr20det engine harness conveted to s14 chasis cut mafs plug and injector plugs- 180 i have the stock injector plugs and mafs plug if you buy the harness you get these if you want them. Momo steering wheel- 80 greddy white 60mm boost gauge electric one- 100 sr20det BUILT motor with new bears seals water pump oil pump s15 pistons 1.1 mm apexi head gasket Brian Crower stage 2 264 cams rocker arm stoppers peak performance valve springs arp head studs polished valve cover basically brand new motor barely broken in and taken out of car- 2000 ALL PRICES ARE OR BEST OFFER here are the pics ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() pm me or email me at Guildjs@gmail.com i will ship anywhere...paypal or cash only |
Definitely wanna pick up that S14 Rear STB if you're local to Socal. Emailed.
