how to 100% turn VDC off
This is a discussion on how to 100% turn VDC off within the DRIFTING Technique Forum forums, part of the DRIFTING Technique category; i want to drift my350z i want to 100% turn the VDC and TC and ABS off. i was heard ...
Old 11-20-2004, 11:36 PM   #1
tashi
Unhappy how to 100% turn VDC off
i want to 100% turn the VDC and TC and ABS off. i was heard some 350z driver said pull on the fuse box, take out the VDC , ABS fuse. it will disable the VDC
is it right ?????
tashi is offline   Reply With Quote
Old 11-21-2004, 04:50 AM   #2
Ris4drift
if you take a fuse out of an system run by electricity it normally disables it
Old 11-21-2004, 06:15 AM   #3
z-dorifto
The square red 50 fuse in the fuse box by the battery will disable VDC, ABS, and TCS (Brake, Slip, ABS, and VDC warning lights will stay on)
Or you can disconnect the Yaw sensor (located under center console just below e-brake) which is the small Bosch sensor by removing the center console. This will only disable VDC, TCS, and EBD (electric brake distribution) VDC, Slip lights will be on. HTH
z-dorifto is offline   Reply With Quote
Old 11-22-2004, 08:10 AM   #4
tashi
after i take the fuse back to the fuse box, do ABS and VDC signal light will keeping stay on???
