drifting with a 300zx
This is a discussion on drifting with a 300zx within the DRIFTING Technique Forum forums, part of the DRIFTING Technique category; i have been trying to drift with my 300zx...but i can't do it. i posted this in the noob section ...
Old 02-08-2005, 04:41 PM   #1
pom_sandhu
pom_sandhu's Avatar
i posted this in the noob section and all i got was keep trying.
can someone tell me a technic to use when drifitng with a 300zx (i tried the ones that are posted in sticky).?
pom_sandhu is offline   Reply With Quote
Old 02-08-2005, 07:02 PM   #2
NismoSigma
Driftin' to the MOON!
NismoSigma's Avatar
Send a message via AIM to NismoSigma
What sort of modifications have you done to your car? Do you have a new suspension or anything that would change the aspect on how the car would perform during drifting or regular driving? If you dont have an LSD I suggest that you look for a lsd from a 300zx. It is realitivly harder to find one but it can save you lots of money. Here is a link if you need some more information. http://www.zilvia.net/installs/lsd/lsdswap.asp
NismoSigma is offline   Reply With Quote
Old 02-08-2005, 08:22 PM   #3
Mr0d
Mr0d's Avatar
Send a message via AIM to Mr0d
Get up some speed, then turn crisply into the corner u are entering and yank that ebrake.. works every time for me
Mr0d is offline   Reply With Quote
Old 02-08-2005, 09:00 PM   #4
pom_sandhu
pom_sandhu's Avatar
my Z is stock.
Im not a person that is literate in mods. I don't even know what a LSD does?
Ill try that Mrod
Old 02-08-2005, 10:02 PM   #5
Mr0d
Mr0d's Avatar
Mine is stock too for now.. but um yea u gotta get the weight atleast shifted before pulling the e brake or ull just keep going straight with the rear wheels locked since the z is a front heavy mother
Old 02-08-2005, 11:23 PM   #6
mechaniac
nuckin futs!
mechaniac's Avatar
I'm not a big Z32 or Z fan in general. But if I remember correctly, the Z32s had rear steering.(Like HICAS on some 240s) If so, that setup makes drifting even more difficult.(really difficult actually) Not to mention the heft of the car itself makes drifting harder.
Old 02-08-2005, 11:34 PM   #7
AE86_drift
Keepin it sideways
AE86_drift's Avatar
Send a message via AIM to AE86_drift
Is it a Z31 or Z32? If it's a Z32, is it the Twin Turbo model? If it is, than mechaniac is right and they have HICAS. That makes your rear wheels turn for a better turning radius. Horrible for drifting. If it's a non-turbo, it doesn't have HICAS.
As for drifting it, try getting on the gas comming to the exit of a corner. You will get to understand how the car feels when it starts to get sideway, plus you don't need to be going fast to get it to kick out. When you feel a little more comfortable, rip up the e-brake going into a turn, but only a little bit.
AE86_drift is offline   Reply With Quote
Old 02-09-2005, 05:56 PM   #8
SilverGhost
touge sleepy-eye 180sx
SilverGhost's Avatar
have you tried straight up clutch kicking it? also, those cars are very hard to drift because of the nature of them, they are very spin happy cars like supras and MR2s. prtly because their weight balance isnt the best for this sort of thing, and the suspension geometry wasnt terribly well setup for drift on a stock Z platform car. as well, OE struts that are 20 years old dont perform as well as they did in 1980-something. these are just acouple things i found out while drifting an 82 280zx...also, you must steer way in advance to your manuvar to help keep it from spinning. the ebrake works good as well. to get sideways around a nice 90 degree corner, coming in in fourth and heel and toe down to like 2nd works like a charm well, hope that helps, and good luck
Old 02-09-2005, 08:57 PM   #9
pom_sandhu
pom_sandhu's Avatar
i think im gettin there....at least i can get it side ways (alitte)...hahha
thanks guys
Old 02-09-2005, 10:55 PM   #10
mechaniac
nuckin futs!
mechaniac's Avatar
Which Initial D character are you?
You are "the rock in the corner of one of Akina's hairpins"
You sit there all day long watching the world go by. Probably because you can't move. You can't wait until night time when the cool racers come flying down the hill because the hairpins are where Takumi usually wins a race.
If you were anymore worthless, you would be like the american kids paying more than 2k for a rusted 20 year old car that needs an arm and a leg to make operate like a normal car.
Old 02-13-2005, 09:29 PM   #11
shearinfinity
It's true that TwinTurbo Z32's have Rear Steering (HICAS = HI Capacity Actively controlled Suspension) but the rear wheels will only turn up to ONE degree. Nothing that anyone would notice and should feel invisible. Also ALL z32's have LSD. Hope this helps.
shearinfinity is offline   Reply With Quote
Old 02-24-2005, 09:05 PM   #12
slideways2004
slideways2004's Avatar
ALL z32's have a vlsd. and the tt's have that hicas. it shoudn't be that hard to get the tail-end out. you can do that in any rwd car. if you can't do that then you have some problems.
slideways2004 is offline   Reply With Quote
Old 02-28-2005, 12:40 PM   #13
Silverbullet
all 300zxs come with an LSD. It's viscous but its better than nothing. Whats your problem? You an't get the tail out at all or you just spin out? its real easy to get sideways with an lsd.
you should try to begin with doing circles around a stationary object. Also practice doing J turns.
Silverbullet is offline   Reply With Quote
