stop my understeering 510
This is a discussion on stop my understeering 510 within the DRIFTING Technique Forum forums, part of the DRIFTING Technique category; well i just did a gymkhana and realized how much my car understeers. i have to clutch kick it hard ...
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 06-26-2005, 09:33 PM   #1
Hachi-roku04
waiting for my hachiroku
Hachi-roku04's Avatar
Send a message via AIM to Hachi-roku04
well i just did a gymkhana and realized how much my car understeers. i have to clutch kick it hard to get it to start sliding. any tips on stopping this?
Hachi-roku04 is offline   Reply With Quote
Old 06-26-2005, 10:31 PM   #2
O5m0515
Drive faster.
O5m0515 is offline   Reply With Quote
Old 06-27-2005, 02:17 AM   #3
SpazmSi
Wow that last post was worthless, I have no idea what the suspension of the 510 even looks like so I can't offer any more useful info then that last guy, I wonder if he even knows what gymkhana is....
"just blast past some of those cones in the middle, skip the one people are 540ing around, and carry more speed into the last set, the weight transfer should take care of you.... better yet do a RB26DETT VTEC swap that'll fix it!!"
SpazmSi is offline   Reply With Quote
Old 06-27-2005, 07:47 AM   #4
UberSpeed
UberSpeed's Avatar
Spazm, not trying to start anything, but how exactly was your post any more helpful. You offered no advice and did it with 40 times as many words. Driving faster should help. The car will have greater momentum, allowing the rears to break free a little easier. A good ol fashion yank of the E-brake, while not the cleanest or most respected method, should also do the trick.
Also, I'm guessing the suspension looks like this - Spring coiled around a shock. Just a guess.
UberSpeed is offline   Reply With Quote
Old 06-27-2005, 07:52 AM   #5
pusher
1'' thick carbon fiber rear sway bar. Has to be carbon fiber no other material is jdm enough.
500lbs/inch springs in the rear.
inflate rear tires to like 60 psi.
Do that and then post on how to keep it from spinning out.( if you look through my bs those are some legitimate reasons.)
pusher is offline   Reply With Quote
Old 06-27-2005, 09:03 AM   #6
sdtouge
sdtouge's Avatar
it might be becuase this was your first time doing gymkana and you only put your tires at 30psi
saw the video though really smokey *Censored**Censored**Censored**Censored* lol
Old 06-27-2005, 09:39 AM   #7
Hachi-roku04
well i ran 30 in front and 40 in rear. My max is 44. The car isnt really setup to drift. Its super hard in front and fairly mild in back. If u get a vid from someond it would probally help. Btw i get snap oversteer like crazy! But it was my first time so o well
Old 06-28-2005, 06:27 AM   #8
cfrost
cfrost's Avatar
With gymkhana you might want to try using your ebrake with a little clutch kick on turn in, it works for me
Old 06-28-2005, 01:58 PM   #9
DRIFTER-M
-yes, yes I am sideways-
DRIFTER-M's Avatar
Send a message via AIM to DRIFTER-M
Welded diff, that will prob stop your understeer
DRIFTER-M is offline   Reply With Quote
Old 06-28-2005, 02:12 PM   #10
techtrix
techtrix's Avatar
welding your diff make make your car understeer more, unless you snap the car sideways and make the rear slide... if he cant get the car to slide now theres another problem. i have a 510, its a turbo rotary, the blue one that was in sport compacts ultimate street car challenge. i had a welded diff and it sucked. i had no e-brake and i couldent clutch kick it cause i broke half shafts doin that, so the car pushed bad. i had to enter the turn way to hot, turn in a little to get some weight on the front wheel, lift the throttle, left foot brake, turn in more then it would start to slide, and then get back on the gas to steer the car arround the turn ( i wasent drifting this was on a road course). what is your suspension set up? what shocks, springs, sway bars, bushings, camber plates and so on do you have? how low is the front, is the shock bottoming out? that causes understeer and is pretty common on the 510
techtrix is offline   Reply With Quote
Old 06-28-2005, 03:19 PM   #11
O5m0515
If max is 44 do 44 in front and 48 out back. Dive in deeper and use carefull brakes to pivot. Whe I started out I set up a cone in a parking lot and with out ebrake or clutch I could dive into and pivot directly around the cone using just brakes. So start out by driving faster :P
Old 06-28-2005, 04:46 PM   #12
Hachi-roku04
thanks for the help
my 510 is running celica kyb cartrages in front and mr2 cartrages in rear with nissan competition springs. the springs are hard in front and mild in the back. i have no ebrake. i have no problems geting sideways with my lsd. its either understeer to snap oversteer. ive yet to find the happy medium
Old 06-28-2005, 05:43 PM   #13
CrazyBadger
Rice Killer
CrazyBadger's Avatar
I'm no suspension guru, but I think the rear is supposed to be stiffer than the front.
CrazyBadger is offline   Reply With Quote
Old 06-28-2005, 06:04 PM   #14
techtrix
techtrix's Avatar
no, the front should be stiffer than the rear in a front engine car.. rear engine car like a porsche would be stiffer in the rear. do you have a front sway bar? rear sway bar? if you have one in the front disconnect it. that will make more weight transfer to the front of the car and make the rear lighter.
check your front shocks also by jacking up the front of the car, then put a zip tie arround the chrome shock shaft right at the bottom where it goes into the tube(make shure its tight so it wont slide by itself), then put the car down, drive it hard like you were before(dont do it on the street) and then jack up the front again and see where the zip tie is. if its close to the top or at the top your shocks are most likely bottoming out, then what you need to do is pull the spring off, and push the shock all the way into the tube and see where it bottoms out, some shocks bottom out before the chrome shaft goes all the way into the tube. on the rear suspension, have you modified it to adj toe? if you havent you probobly have a bunch of toe in and that will make it snap oversteer. what motor do you have in the car? stock L series or is it a KA or SR? a heave front end will cause a push also...
Old 06-28-2005, 06:14 PM   #15
pusher
Depends on what car, on some of the older cars the rear squats so bad that you need higher spring rates in the rear. Yes, even when the engine is in the front.
Old 06-28-2005, 08:33 PM   #16
Hachi-roku04
thanks tech for some real help. i have a l20b. and i should adjust the toe in the back. its pretty agressive toe in. should i have toe out or neutral setting?
Old 06-28-2005, 10:39 PM   #17
techtrix
techtrix's Avatar
what front engine car has a stiffer rear spring than the front??? im not talking about backyard drifter setups, im talking about proper road race setups... and dont forget about the difference between spring rates and wheel spring rates. different placements of the spring or shock spring combo are what really matters. you might have a 500 lb spring but at the wheel its ony 250 lbs because of leverage.
on your 510 rear toe i would run 1-2 mm toe in. and on the front, if your going to be road racing id put it at 1 mm toe in, and if your drifting or your on a slow speed auto-x course id put it at 0-1 mm toe out to help the turn in
Old 06-29-2005, 08:34 AM   #18
Hachi-roku04
thanks again tech. i can visually see my rear toe in. so its gotta be at least 4mm. how stiff would you reccomend the rear being. to get my car to ride level i believe i have to cut 1.5 coils. thats what they did with the nissan competition springs
Old 06-29-2005, 09:57 AM   #19
techtrix
techtrix's Avatar
i would just go with the springs you have now, nissan comp springs are good. 1.5 coils cut off should be no prob, but you should think about getting 280z front struts and brakes,(if you dont already) the brakes are way better and the struts are 1.5 to 2 inches shorter so you have more front suspension travel. but you will have to cut the spring perch off and weld on the 510 one or weld on a coil over sleeve.
Old 06-29-2005, 05:14 PM   #20
Hachi-roku04
i have a full 300zx disc brake conversion already
