Shift lock (compression slide)
This is a discussion on Shift lock (compression slide) within the DRIFTING Technique Forum forums, part of the DRIFTING Technique category; “Initiated by downshifting (usually from third to second or fourth to third, and using a very fast shift) instead of ...
Old 04-16-2008, 10:13 PM   #1
davidbeau
“Initiated by downshifting (usually from third to second or fourth to third, and using a very fast shift) instead of braking, without rev-matching, causing the drive wheels to lock momentarily. Helpful for very tight corners, allowing the driver to approach the corner at a slower speed and lower revs, while allowing quick acceleration when exiting the corner. This technique can be very damaging to the engine if mis-used as the ECU is unable to rev limit when the engine is oversped by the rear wheels. Premature downshifters are called "Rod Stretchers".”
________________________________________
See my CarAnatomy Blog...
davidbeau is offline   Reply With Quote
Old 04-16-2008, 11:17 PM   #2
Piner
Piner's Avatar
doubleu tee effff mate
Old 04-17-2008, 09:17 AM   #3
eomund240
Compression slides are a really effective way to get the car to drift. In fact it's one of the only ways to get an Open Diff to get both wheels spinning (from experience). It is increadibly hard on the engine if you do it wrong though. It's also hard on the tranny, the syncros, and the clutch. But generally professional cars don't need to worry about that.
Old 04-17-2008, 11:16 AM   #4
Piner
Piner's Avatar
why just a random post describing a shift lock? I mean doesn't everybody already know what it is why do we need a single post to descibe it when it have been talked about many many times before
Old 04-17-2008, 04:12 PM   #5
cfrost
cfrost's Avatar
^that and...... why talk about it? it's probably the worst possible way to start a drift just under putting trays under your rear tires in a fwd car
there's no practical use for it and plenty other better stuff you can do to make a car go sideways, open diff or not
Old 04-17-2008, 04:34 PM   #6
eomund240
I'd have to dissagree with you. Yes there are many ways to initiate a drift. But compression slides are extremely effective. I'm not sure why you're saying it's not a good way to drift.
I've found it's more effective on underpowered cars, like the SR5. It was one of the techniques I used to get the thing to kick out. It's also a very predictable slide.
Saying it's the worst possible way to drift is far from correct. And just an FYI, some of the top drifters including Koguchi and Ueo use this technique.
Now I agree that starting a random thread about it isn't necessary, but don't diss a technique just 'cause you don't like it or can't use it.
Old 04-17-2008, 06:25 PM   #7
cfrost
cfrost's Avatar
sorry i'll try to learn something about drifting before i make a stupid post again
Old 04-17-2008, 07:21 PM   #8
biggslava
biggslava's Avatar
hahahahaha
biggslava is offline   Reply With Quote
Old 04-17-2008, 09:45 PM   #9
soultron
soultron's Avatar
That's what a man does. Colifros is so legit.
Old 04-18-2008, 08:27 AM   #10
eomund240
I never said you didn't know the basics of drifting or questioned any of your knowledge for that matter. I was ranting on the statement that it's the worst way to innitiate a drift because it's far from accurate. If you want to make sarcastic comments that's fine and dandy, but it's a legit technique.
I could always come off with the n00b comment that if Keiichi Tsuchiya teaches it in drift bible it's a legit technique. I'm only joking at this point, but seriously, it works.
