This is a discussion on not enough HP! within the DRIFTING Technique Forum forums, part of the DRIFTING Technique category; so i was driving my car around my favorite road and started trying to get her to drift to get ...
not enough HP!
so i was driving my car around my favorite road and started trying to get her to drift to get it to get going at all i had to flick it dangerously hard i think i need more HP to get the back wheels out
or stiffer suspension ![]() but i think its my glorius 100HP coming out of my rotary does good in first and second car is made for a go kart track
#2 | |
Re: not enough HP!
![]() What specs are yours? |
yeah, i could drift my FC when it was stock plus clogged cats so i don't see why you'd have a problem unless you're running some wide sicky tires in the rear.
Its not about power. If you cant spin the wheels with power then transfer some weight. um YO
May i sugest enter the corner extra fast, tap the brakes hard to transfer it to the front when turn. It may not even take any power to get it sideways with that technique. |
see i could flick it into a corner like that but im drivng an FB
so it has snap over steer and 4 tunr lock to lock steering if im not in control of the car i will wreck |
practice somewere you can get alot of speed up safely and practice tail braking.
touge sleepy-eye 180sx
this is a great technique....i foigured that out, and its alot easier on your motor/tranny, just make sure you have good brakes up front, and brake drifitng isnt that hard (considering we are talking about drifting here, an alrready challengng motorsport).
and with this move you will also keep great grip upfront and front tire grip = control = not crashing go have some more fun man!!! |
Operation 12A>13B
I drive an '85 Rx-7. I've drifted it just by applying the brakes on an off ramp. I think I was going 55mph. Just pressed on the brakes too hard when I was turning but I went with it. I don't think you need more hp. I'd rather have better susp. than more hp, but hp is cheaper right now than susp. You and I are the only ones with FBs as far as I know. Just have fun and be safe. Braking drift is fun. Weeeeeeeeeeeeeeeeeeeeeeeeeeeeee
chevette = 60hp.
100hp would scare me. scare me into drifting more. |
#10 | |
Operation 12A>13B
Mine was completely accident on dry smooth no rocks/sand pavement. Good stuff. Left some smoke.
HP is not needed to drift. about right now, Ueo is considered the top drifter in the D1GP and he has about 180HP. sure it is a lot compared to your guys cars, but compared to other D1GP car where HP does not dip below 300HP, it is proof power doesn't matter. as long as you have enough to spin the tires.
if you can't get the rear end out you can a) put crappy tires or up the air pressure in the back tires(try to make the contact patch less somehow) or b) get better. rock.
boro hachiroku driver
ueo is not considered the best drifter in d1 right now and there quite a few cars in d1 under 300hp...
one car has 100!!
#15 | |
from what I heard, yes he is. show me proof that he isn't please. rock.
#16 |
OMG the ground's white!
Yep, braking drift is a pretty safe way to initiate a drift. The rear end comes out smoothly and can be controlled by braking strength. If you're having a hard time to get the car to drift, brake into the corner and feint a little, just a slight out and a quick flick in. You can feint while braking or start it just before. Just flick in when you start braking. This will both throw the rear end out plus move the weight off the rear tires. This should get any car to drift. Then just floor it and countersteer. With 100hp, you'll probably have to hold the gas to the floor and keep it there until you exit the corner. If you let off, it will catch. If you feel it catching a little, just steer a touch more into the corner. If it's spinning out on you, let off the throttle for a second and the rear end will catch a little. You can just counter steer more too. If all else fails, let it full lock and brake hard. The car should come to a halt at whatever angle you were sliding. Just get quick with the steering. If the rear end catches fast, you'll have to get used to straighten out the wheel quickly. It's helpful to be smooth with your actions. Don't feel so bad, most cars are 3-4 turns lock to lock. My old Ragner is 8, yes, 8 turns, quick hands, quick hands, lol.
