FF drift, possible?
This is a discussion on FF drift, possible? within the DRIFTING Technique Forum forums, part of the DRIFTING Technique category; ive tried to drift in my 99 honda accord and once i break it loose i can keep the angle ...
Closed Thread
Old 06-16-2004, 10:02 AM   #1
AE86GetSideways
Question FF drift, possible?
ive tried to drift in my 99 honda accord and once i break it loose i can keep the angle by using the e-brake but i loose too much speed, ive tried giving it just short bursts like shingo does from Initial D but I always cant keep my speed up to exit the corner at reasonable speed. Any ideas on how to do this??
Old 06-16-2004, 11:59 AM   #2
mranlet
mranlet's Avatar
More power or RWD
mranlet is offline
Old 06-16-2004, 12:32 PM   #3
nissanguy_24
nissanguy_24's Avatar
Indeed. You can see the problem with drifting a front wheel drive. Now its not undoable. May i sugest you work on initiating a drift with trail braking or some other technique, then using the hand brake only to prolong it?
nissanguy_24 is offline
Old 06-16-2004, 12:34 PM   #4
chuaboi36
chuaboi36's Avatar
Send a message via AIM to chuaboi36
wait so what would be a reasonable amount of power for fwd? still tryin 2 get my crx goin.
chuaboi36 is offline
Old 06-16-2004, 12:56 PM   #5
GRiDRaceTech
GRiDRaceTech's Avatar
This thread should be closed, the same question has been asked several times before. (And discussed ad nauseum in the car mags and other forums)
GRiDRaceTech is offline
Old 06-16-2004, 01:08 PM   #6
pio_masaki
pio_masaki's Avatar
Send a message via AIM to pio_masaki Send a message via Yahoo to pio_masaki
Well, as already stated it IS possible, just not as much for show, and usually end up being slower then just taking the turn correctly for grip. My 90 civic LX drifted..well, as close as it could, under heavy braking and shifting the body weight, much the same as a RWD could, but it was simply due to the drums in back, they liked to lock up at the drop of a hat, and from there throttle to push the front end out, ebrake to get the back end out, and back and forth until you're either done and exiting, or wrapped yourself around a pole=) It was an auto, BTW, and whenever I would actually attempt this little trick I would plop her down into second to lock her there, and some brake pedal usage was needed to aid in over all speed control. It is MUCH easier to control in a RWD car, so while it may be fun to learn how to drift a FF car, I would save it until after you get a RWD, or if you already have a FF, go ahead, just be careful (well, that goes without saying I guess =P )
This is just how it worked for me, and while I didn't do monster drifts, or even look good doing it, it got the job done since alot of the time it was accidental in the first place. Crappy tires helped alot too, I'm sure. I kind of miss that car, R.I.P.
pio_masaki is offline
Closed Thread
