This is a discussion on Controlling a Drift? (E-Brake? or Letting Off the Gas..?) within the DRIFTING Technique Forum forums, part of the DRIFTING Technique category; I had a quick question. So after initiating a drift in a FR car, the rear starts comming out. What ...
So after initiating a drift in a FR car, the rear starts comming out. What is the best way to control the rear when it starts comming out too much (you are at oppisite lock but it still keeps turning)...? Would it be quick pulls on the E-brake? or letting off the gas..? Thanks. |
Horny mofo's coast2coast
let the gas.... if you pull the e brake the car will spin....
Large Member
if you completely let off the gas the car will "bite" just like when superbikers let off the throttle while they power over at the corner exit and they get thrown as high has 20 feet in the air. the car will jerk suddenly into the direction that you steering wheel was turning and you will crash. When this used to happen to me in my hachigo i would slam on the brakes and let the car go in reverse (you must have skill to do that though, but you probably wont crash this way)
So ease off the gas, but don't let go... or else the car will snap back. I've had that happen a couple of times, I too just slam on the brakes and kind of go into a 180 and just roll out of it.
Any other methods? |
#5 | |
I was having the opposite problem, I couldn't get enough of my tail out... Stupid Automatic Transmissions... Matt. |
Not spinning at opposite lock comes with a lot of practice and throttle control.
If you use the handbrake as a rear brake and don't lock it up, you can also just slow down the rear a little bit without stepping on the brakes. This has the same effect as easing off the gas. |
OMG the ground's white!
All good points.
I'd suggest changing your technique to help prevent the overly high drift angle. Initiate it a little more subtly to create a lower angle. You less throttle and more steering to start the drift. Use less feint or braking, or e-brake or whatever you do to start it. If you're at opposite lock and still spinning around, you threw the rear end out a little too much to start with. The rear end should come out a little easier. With that said and you still find yourself in the situation of over rotation, i.e. pretty much a spin out, you have few options. Most have already been stated. Let off the gas. This will allow the rear tires to regain grip again and straighten out the car. Be very cautious when they do regain grip cause that rear end will snap back and snap back fast. This is where good hand speed comes in. Learn the straighten out the wheel as the rear end regains grip. By the time the rear end has traction, the front tires better be pointing straight. If they're still at full counter, you'll essentially drive yourself straight into the ditch or wall. When the rear end regains traction, the car will head where the front end is pointing it. The e-brake idea is a good one. Using it lightly will basically drag the rear end a little and will help prevent the rear end from overtaking the front. It will slow you down as well. You again have to be cautious. If you lock them up, you could just continue to spin out, if the rear sliding is an easier path of motion than the front rotating. I too do enjoy a good full 4 wheel lock up. If all else fails, this is the one thing you can count on to help get you out of a jam. Reguardless of throttle, braking, steering angle, this will do the same thing every time. Just lock up all 4 and slide to a stop. I did this a few times when I was learning on rwd and trying to drift in the dark(having not done so in the past). I had a hard time judging where my front wheels were pointing, how far they were turned or even if they were straight or not. With 8 full revolutions from lock to lock in darkness, it's hard to tell where you're really pointing, lol. Still, old faithful helped me out when I got 'er swaying back and forth uncontrollably trying to figure out where the heck my front wheels were pointing. Hit the brake, and slide to a stop, nice and easy, no fuss. Oh a little off topic but related to what I just said. If you're relatively new to drifting and are in fact trying it in the dark, I'd actually suggest trying it in daytime. The gained visual reference is tremendous and may help you out quite a bit when learning the basics. You have a far greater sense of what's happening around you, where you are oriented, and which direction you are moving. You'll actually be able to see the steering wheel too, which I found suprisingly handy in the above mentioned vehicle, especially when starting out with drifting. Where to go in the day time? Some back country road with no traffic and a few good corners...if you can find a place. Otherwise a parking lot and a few cones. If you're quite law abiding, see if there are any tracks around where you live and see if they have times you can take your car out on it. |
Boro Miata
let go fo the gas steer the other way when u feel the car jerking...it's steering inputs if you know how to contorl the car with yuor steering a "over drift" isn't to hard to fix...
#9 | |
If your getting a snap-back after letting go of the gas, this is because of the outside tire retrieve it's traction first before the inner tire. Causing the car to stop off it's track for a second which cause the snap back. If you have an LSD. Both rear tires looses and retrieve it's traction at the same time, which gives it a smoother transition from loosing traction to gaining traction again. If you have an open diff. Ask a friend that have RWD car that has an LSD. You'll see the difference. |
#10 | |
Large Member
Sample One Time!!
Everyone is covering the driving technique aspects, but I thought I would bring up tuning aspects as well. I would say its most common that excessive ammounts of oversteer (resulting in a spin) is a result of driving technique. But if you consistently find yourself in that situation after changing your technique then you might want to consider your car tune as well. Suspension adjustments can really affect the way your car oversteers. From my experience, changing your swaybars makes the most noticable difference. The general idea is that bigger in the front = more understeer and bigger in the rear = more oversteer. In my case, my previous car was underpowered and I wanted more oversteer when feinting, so I put on a bigger rear swaybar. Now with my new car I have a lot more power, but the stock swaybars give me too much understeer. I need to use excessive ammounts of throttle to keep the rear out, and usually thats what messes me up. I need the car to have better natural oversteer tendancies. So I'm gonna take the swaybars from my old car and swap them over since they were matched well for drifting. In your case it sounds like you have too much oversteer, so maybe a smaller rear swaybar would do the trick. Another possibility could be the tires.
But usually, having the problem you describe is related to driver input. Use less throttle or less violent weight transfer and the azz wont swing out as far. IMO changing your technique can overcome most tuning problems/issues. The perm fix should be correct tuning, but a temp fix can be modified style. So even with your car tuned for excessive oversteer, you should be able to overcome any problems by adjusting your style. If you still find yourself with too much oversteer then maybe mess with the swaybars, tune, or tires. Anyway, thats my .02 |
stop spreading disinfo
i think you guys should just keep trying different things and see what works best for you. some people let off the gas and turn the wheel back. some tap on the gas and turn the wheel. some hit the brakes a little and steer.
#13 | |
Now Rockin Roadster #2!
Thrillz |
just let yourself FLOW....do not freak out, do not really think, just let your reactions judge your movements...
a normal reaction that is right is to countersteer a normal reaction that is WRONG is to let off the gas totally. be easy with the car, and the car will be easy to drift... you might have to clutch kick it into a drift before you apex the turn.... but what do i know, my supra is still being built up and i havnt drifted in 1 year......i just read alot...
#15 | |
#16 |
when it starts to happen i stay on the gas and i mess with the clutch like hold it half way down what not and that always seems to save my *Censored**Censored**Censored*.
#17 | |
Large Member
#18 |
something to consider also is the type of rear tire your using and also tire pressure too... if its too crappy or too much air the rear end will come out more or faster since there isn't too much grip back there due to no tread or crappy compound, or too much air. letting off the gas until you feel comfortable again is always a good way out if you have a LSD if not then using the side break to slow the wheel spin is the best bet. Modulating (not pulling the side and holding) is your best bet in bringing the rear in check. once you get the rear in check you can continue drifting, since it will happen real quick you'll get the feel for when you have slowed your self down enough.
#19 |
another way to keep a car sideways is to let off the throttle VERY HARSHLY, for merely an instant, and then floor it again. It will transfer weight to the front, and kick the tail out a bit.
one exercise that would be good for you is learning to modulate the brakes to keep you sideways. Once the car is sideways, more brake = more angle. Try it. Some drivers even like to left-foot-brake... all depends on your style. Like Marshun said, just try everything you can think of. See what's best for you. |
#20 |
Got a date with Lady Luck
Everything totally depends on your car's level of tune, your skill and technique, tires, and the corner speed. Most of what is being said woudl work, you just have to find out what is right for you. If youa re like me and enjoy a lot of angle throughout the whole turn while keeping the speed (higher entry speed is needed) you will set up your car to slightly understeer. Because a feint with clutch kick into power then sidebrake then power will get you sideways everytime, no need have an oversteering car. THe "understeer" once in the drift will "walk" your front end outward so at high angles, you rears are smoking and sliding a lot and the fronts are VERY SLIGHTLY understeering or sliding towards the outside as well. Only at high speeds though. As the corner slows down your front tires will always have grip (unless you front lock them at the apex). FOr me, to control it (i have full 2 way LSD) i just let off the gas all the way until my rear end stops coming around on me, then right before it may grip or gain tooo much traction, get back on the gas and keep the revs up. *Knowing* when to do this is a matter of experience and practice.
#21 | |
#22 |
Uh... i don't get it.
My practice is nothing? As in what? Where i go drifting is easy? Ummm there is a thread by Scirocco in the pics forum that shows a video of me and some friends drifting. If you think that turn is easy then you are more insane than me... simple as that. Edit: Here/ Yeah its super easy: http://www.drifting.com/forums/showt...&threadid=8402 Last edited by _PG_; 09-20-2004 at 01:22 PM. |
#23 | |
#24 |
I crashed twice. in one night, in the same spot, actually. Its ok, i fuc.ked up, and learned more from crashing than i would have if i had made it. Crashing is enevitable and it is expected. I always keep that mentality.
How many cars have any of the top (D1 for instance) drivers gone through? SO MANY. "Drifter-X" Komatsu has gone through 7 cars, and he is a good drifter, not a "top" guy. He sure is better than almost everyone i know though. I have crashed planty of times, some bad, some not. Oh well. If you haven't.... just wait. |
#25 |
Sample One Time!!
Yup crashing is a part of drifting. Its inevitable if you push the limits and try new techniques or higher speeds. And to get to the level of the current professional drivers you would really need to push the limits. Nobody I know that drifts (me included here) is ever ashamed if we crash as long as we were pushing the limit. Now if we just plain screwed up or made some equipment error, then yeah maybe different story. But if it was balls to the walls then nothing to be ashamed of. I dont really push myself hard but I've crashed a total of 6 times on the track so far since I started drifting, and every time I've been lucky and not had crazy damage. I mean, yeah the paint got scratched or the panel got a little mangled, wheel bent up, maybe even the slignment got screwed, but nothing broke off, no glass flew, and I was able to drive away. Now I know other guys that have not fared as good, shattered lights, mangled front ends, broken suspension pieces, head-on's into telephone poles (at the track!), bent frames, car fires and engine fires, whole wheels with tires flying off!, people flipping upsidedown and land on the roof, even some guys that have been through multiple chassis that have been mangled many times, 60 mph glance off a guardrail a few times, that kind of stuff. It happens to everyone. Heck even happened to Alex once when he came to the first Signal event and barrowed Wendells grey 240. Yeah he made a mistake and tapped the wall but nobody was talking crap. It happens.
