DRIFTING.com SHIRTS
DRIFTING.com SHIRTS
DRIFTING.com SHIRTS
DRIFTING.com SHIRTS
DRIFTING.com SHIRTS
DRIFTING.com SHIRTS
Left Foot Braking For FF
Old 10-24-2004, 09:21 AM   #26
5zigenek4
Hmm, just thought up of another thing. Now when you apply the e-brake, you'd have to counter it with increased throttle. A question for you: Would this increased throttle and resulting increase in forward force on the front tires fully counteract the torque produced by the e-brake?
I think its supposed to be balanced. I think...
Straights are for fast cars~
Corners are for Fast Drivers~
5zigenek4 is offline   Reply With Quote
Old 10-24-2004, 09:53 AM   #27
Parry
Parry's Avatar
Well...you'd be using the foot brakes not the ebrake, and yes you do need to feed in more throttle to make up for the braking force.
Old 10-24-2004, 12:26 PM   #28
SidewaysGts
SidewaysGts's Avatar
The monkey who brought up LFB was correct actually. The cartoon is nothing but that, a cartoon. But when they bring up LFB they show live footage of of circuit racers and their use of lfb outside AND the foot work inside the car.
Unlesso f course you think they staged a circuit race where peopel are using LFB just for initial d for some reason?
Old 10-26-2004, 12:30 PM   #29
Drifterlunchb0x
Location: The Great fantastically wonderfully wet Northwest!!!
Send a message via AIM to Drifterlunchb0x Send a message via Yahoo to Drifterlunchb0x
left foot braking is just an all around good technique be it awd rwd or fwd...ive used to it get all of the listed drive types sides ways...awwww thank God for rally drivers!!!
Drifterlunchb0x is offline   Reply With Quote
Old 10-26-2004, 01:33 PM   #30
Jonny_Pham
Best Motoring's Touge Battle has a small part where taniguchi is driving a Eg6 and he uses a little bit of left foot braking techniques. Its not a lot but its still something.
Jonny_Pham is offline   Reply With Quote
Old 11-11-2004, 12:45 PM   #31
ReavTek
ReavTek's Avatar
Send a message via AIM to ReavTek
Left Foot Braking is used for two things:
1) Weight Transfer to provide more grip to the front tires.
2) Rear Wheel Lock, Since an FF is overpowering the front brakes the rear brakes receive more brake force and hence this is an effect similar, but not as drastic as an emergency brake.
Where you can learn about it:
1) Check out track events or driving schools.
2) Best Motoring's Battle At 10,000 RPMs is a great summary of honda's and shows a considerable amount of left foot braking on it's Togue Battle section in an Integra Type R, Civic Type R, and a Prelude.
ReavTek is offline   Reply With Quote
Old 11-11-2004, 01:13 PM   #32
SidewaysGts
3rd reason: Keeping a turbo spooled up.
Old 11-11-2004, 03:37 PM   #33
D1Skyline
Nissan Fan
D1Skyline's Avatar
Send a message via AIM to D1Skyline
Interesting thought
Hey, I have an interesting thought about left foot braking. As I was thinking while reading this, I remembered that the front brakes are usually larger and more powerful than rear brakes, so that means for FR car if you left foot brake, since power goes to the rear, that means u slow down mainly the front tires, while the rear tires even out from the engine power, while on a FF car it can induce rear loss of traction to react like FR because the front tires are evening out with the brakes, while the rear tires are just braking, so it would cause Left foot braking to be different for each type of drivetrain, while AWD left foot braking i guess would be a turbo spooling technique because all wheels are evened out. I notice that before everyone is stating how it slows down the rear only, but when you apply brake it causes both front and rear to brake, but normally only 1 side either front or rear is getting torque from engine, so that would mean its like an opposite brake technique, so yea this is what I was thinking about, so if anyone else have any ideas about this?
"Before you drift, call a repair shop and your insurance company"
D1Skyline is offline   Reply With Quote
Old 11-11-2004, 05:47 PM   #34
SidewaysGts
Left foot braking can be done in an fr but in all hoensty theres much better ways to take a corner (unless were tlaking cart, those guys onyl have 2 pedals anwyays.. and..well thats just different).
In FF lfb can be enouch to ofset the traction of the tires a little and create minor slip angles. because of that it will help with understeer (once again, there are however better ways to clear a corner in most cases)
In an fr however this isnt really the case, its much more effective to brake in as much a straight line as possible then use the tires as best you can to corner the vehicle. Frs can TYPICALY corner better in faster situations (lowspeed corners, low traction etc FF has advantages because of smaller size lighter weight etc, and for lowtraction they simply have more) because their front tires can be used fully to turn the vehicle, instead of tyring to turn and pull the vehicle.
Old 11-14-2004, 05:45 AM   #35
AusStreetRacer
Also, a FF needs to pull the weight of it's arse into the corner along with the front of the car. Whilst a FR actually pushes the weight of the back of the car in the direction you want to go, making them corner faster again.
I use LFB to improve entry speeds and to correct initial understeer.
Also, if you begin to understeer because you're exiting 'too fast', LFB can be useful just to transfer weight to the front so you're not fighting the inertia of your own arse so much. You'll find the understeer dissappears and you'll keep the revs high on exit. So 'too fast' becomes 'fast'.
I have no idea how fast I can go around a corner using LFB cause quite frankly I'm not looking at the speedo. I might mount a camera to look at the dash and out the window.
Although my estimate on a 90 degree corner that was chirping at 50 km/h without LFB was about 65 km/h with LFB, based on what speed I was doing when I looked at the speedo after I straightened up.
AusStreetRacer
"I'm the guy who you left for dead on the straight. Lucky you had time to catch up after those corners."
AusStreetRacer is offline   Reply With Quote
Old 11-14-2004, 07:57 PM   #36
mechaniac
nuckin futs!
mechaniac's Avatar
left foot braking is for the automagic driving guys. You can be so much faster with good heel-n-toe. Helllooooo, trail braking?
Old 11-14-2004, 08:27 PM   #37
SidewaysGts
Heel-toe is a downshifting technique, not a cornering technique. lfb helps with understeer to some degree.
Old 11-14-2004, 10:45 PM   #38
Parry
Parry's Avatar
You have no clue what is going on
DRIFTING.com T-SHIRTS DRIFTING.com T-SHIRTS DRIFTING.com T-SHIRTS DRIFTING.com T-SHIRTS
View ALL DVD's View ALL Shirts View ALL DVD's View ALL Shirts View ALL Shirts View ALL Shirts
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
