This is a discussion on Double Clutching the Upshift within the DRIFTING Technique Forum forums, part of the DRIFTING Technique category; Another thread prompted me to put this idea forward. Please not this isn't really a 'drifting' technique. Atleast I don't ...
Another thread prompted me to put this idea forward. Please not this isn't really a 'drifting' technique. Atleast I don't think it is.
I've been trying to work out if there's any advantage to actually double clutching on the upshift. I have heard from alot of people that this is completely useless in cars with synchros- but apparently it's actually used amongst some drivers and it's supposed to enable you to get better acceleration. This is my theory: When you're making the shift to neutral - you can pretty much bring the clutch straight up - because the only thing the engine is fighting is the weight of the layshaft and gears, compared to the entire weight of the car like you would experience under a normal shift in normal driving conditions. This is one split second shift. So assuming that shifting to neutral can be done as fast as possible without damaging anything, and the fact is that now that the lay-shaft is spinning at the right speed, you should be able to put it into gear and dump the clutch without any jolt or causing any extra wear. This is a second split second shift. So when you think about it - double clutching the up shift means that yes - you hit the clutch twice - but by doing that, you're enabling yourself to bring up the clutch much faster than you would normally. So you're actually reducing the lag between putting the car into gear and making the power connection from the engine to the wheels. You're basically replacing one long shift with two split second shifts. I mean yeah sure - you can always just change gears and dump your clutch - but that creates that JOLT effect which creates a lag on your engine. In effect you end up keeping your revs up around wear you'd want them more effectively, and therefore accelerating faster. Whaddya think? Guh... I haven't had a good nights sleep in a few days and it's currently 1:02 AM. I swear driving needs to be a job. I'm studying Commerce and I spend too much time playing Initial D, watching Initial D, looking for a new car and looking at my finance options, when I could be studying, or sleeping so I can study better. I've just got a new job and most my money will be going towards the car - I don't think I'll have text-books next semester. I'll probably sell my old ones to help save for my car too the way I'm going. LOL. I'll probably read this when I wake up and think: "WTF?!" Anyone wanna point out any holes in my theory? |
well, double-clutching on up-shifts makes your gearbox last a ***little*** bit longer, it's not worth doing because it wastes time. It almost triples the amount of time that you aren't accelerating, and thus losing time to those around you.
basically, only do it if your gearbox is dead, and all the synchros have stopped working. |
plus double clutching was what old classics had to do with alot of the gear boxes...it doesnt apply to todays cars at all,well unless ur sykroz are blown
. moving on....
Neither of you actually commented on the theory I put forward.
I've heard what both of you have said a million times over. Did you actually read my theory? I'm gonna leave it for a while... and come back to it in a day or two... see if my theory still makes sense to me. When I get another manual car I'll actually test it. Damn auto's. |
yeah, I read it... but two kicks of the clutch will always be slower than one. Also, you don't quite "dump" the clutch on fast single-clutch upshifts, but you can let it up quite fast without making the car shudder (just takes a bit of practice).
There is a technique I used on my old MR2 that had a blown syncro in third gear. I would select neutral, from second, with the clutch out, and then quickly hit the clutch just as I put the lever into third. Worked quite well. Also, I don't get what you mean by the "lag" you're talking about. |
Not going to bother reading what was said though im pretty sure malcom was right on.
Double clutching on an upshift will make you take logner when shfiting. Keep in mind when you up shift your revs need to fall, theres no point in raising them in neutral (which takes time to do) only to let them fall (and take time while they fall) again. Why be in neutral even for a short time, lining up your gears when you could already be in the next gear and accelerating? The only point in doing it is to prevent damage to your synchros/dog teeth, or if you dont have them/theyre broken. ___ Added: You can bring the clutch up as fast when your upshifting as you could while your going into neutral. Just depends how smooth you are on it. The key to double clutching being slow, is your revs -need- to fall when you upshift. Go watch the drift bible and watch out fast tsuchiya upshifts, now tell me if you could use the clutch twice while linging up the gears between the clutch uses, in the same time he moves his foot once. Last edited by SidewaysGts; 10-26-2004 at 09:32 PM. |
Yeah. Probably.
I'm just thinking... Your clutch would be able to bring the layshaft up to speed faster than the synchros. But the time it takes to make the second shift from neutral to the next gear would greater than the time you'd save by using the clutch instead of the synchros to get the layshaft spinning at the right speed. So yeah I guess the only advantage of double clutching is that it'll save your synchros, clutch, and transmission from some abuse - especially if you have a high-powered car, and it also disrupts the balance of the car less when down-shifting - but so does rev matching anyway. So I dunno - maybe people who think they can get better acceleration by double clutching already have *Censored**Censored**Censored**Censored*ed syncros or are just idiots. Or maybe there's just a whole bunch of try hards out their that took The Fast and The Furious as a definitive guide to street racing. LOL ![]() I'm gonna keep putting more research into this until I find out a definitive answer from someone with a qualification or something. Might see if I can get in contact with a professor at my uni who specialises in automotive engineering and physics or maybe the UQ Racing Team. Anyone else got any input into this? |
#8 | |
I dont have any "professional" experience myself, but malcom here races what was it again? Formula bmw? Hes as creditied as they come on these forums.
#9 | |
Get over it. |
^--Cold as ice
LOL.
Thanks Parry I'm done with it |
double declutching to upshift ?
I do it all the time in the morning run to school and office...... Do it only when you need it only..... or it just make u slower .... I think with a normal gearbox, a faster shift ( I upshift without giving any gas...I know some of u do but some give gas when they are engaging the clutch ) is a clearer and smoother shift but for downshift I do 2declutching all the time ......just for fun but not for fast ...and it help the synchros more when u downshift than when u upshift |
Midengine drift?
Ross Bentley basically said it would waste a huge amount of time, but any complete race car driver should be able to do it and also shift without a clutch. You never know when your clutch or syncros will go bad. Also, in endurance races it may be worth it to do all the double-clutching.
for upshifts, no... you don't want to double-clutch, ever. Think about it. You waste 2 tenths of a second a shift. 10 shifts a lap, that's 2 seconds. 800 laps in a 24 hour race, and that's 1600 seconds, or 26 minutes. It's just not worth it. For endurance racing, double-clutch on downshifts, because it doesn't really cost you any time.
#15 |
Normally when downshifting you need to ease up on the clutch (unlike upshifting where you can pretty much go as fast as you can as long as your smooth) to some extent, go as fast as you can and the car will jerk (big no-no for racing! dotn want to upset your balance at the most important time, right before a corner)
Double clutching on a downshfit rev matches (gets the engine speed where it should be for that next gear down and the speed your going) so you can work fast on the clutch. But then again, hey thats why we have the ever so popular heel-toe right? __ On a side not the ONLY time ive ever used double-clutching was on downshifting, and in specific the only 2 situations i use it. One is when i want to pass and need to downshift. Two is when im slowing down slowly in traffic, talking so slow just taking my foot off the gas and coasting is enough to slow down, and i double-clutch when id downshift, more for "fun" then being nice on the tranny or being smooth |
#16 |
i dont worry about this stuff.....i meerly shift and pass...
#17 |
<.S][LVIA PSYKO.>
Location: where's ur location?if in canada i will come to ur house and cut you!!!
umm ya i dont really see how double clutching is gonna help unless ur racing an 18-wheeler lol (it does happen saw it on tv) lol
#18 |
Old thread but this was brought to my attention so I thought I might be able to help out.
Double clutching is not need for upshifting. It does slow you down and it does cause additional wear on the clutch, throwout bearing and pressure plate. The amount of wear you save on the synchros, although some people believe it causes wear, is neglible when compared to all the other parts that get extra wear. The reason for doing it on downshift when racing isn't the wear issue, we replace all the parts before they wear out anyways, it is to have the proper revs so you don't lock up the drive wheels when shifting. Someone mentioned shifting without using the clutch. For a shorter race this is fine but in endurance racing, excluding electronic gearboxes, the clutch is used. This prevents possible damage if you make a mistake. With the migration of electronic gearboxes into the cheaper cars this is going to become a lost skill. Last edited by DanB; 01-10-2005 at 10:19 AM. |
#19 | |
Also, with some cars, double-clutching on downshifts DOES reduce wear. Double-clutching eliminates the stress on the syncros. [/dead horse beating] |
#20 | |
![]() I think you might have misunderstood me. Heel and toe is using one foot to control both the brakes and gas. Double clutching, aka rev matching for the younger crowd, uses heel and toe but is not heel and toe. It is matching your engine revs so that when you selct a lower gear you do not lock up the drive wheels. I do agree that it reduces wear, when done correctly, on the synchros. It does increase wear on the clutch and related items though. I know you understand this and I was not talking down to you. I explained it in more detail for anyone else that might read this. I think it was a case of us thinking the same thing and sayiong it differently. BTW is that your car in your sig? EDIT: Realized your sig was a link and followed it. I was recently crewing for a GT1 Vette locally here in chicago. The team owner wasn't too savy so that was short lived. Oh well it was just for fun so no money lost.I see you are interested in ALMS. It has been a while but I used to crew for a few IMSA teams and have been to Sebring for the 12 hr. It is a lot more fun doing enduros. I have also done a few 24 hr SCCA races for a 3 car team racing some smaller classes. I miss the life but I now have a wife and 2 kids so it is a fair trade.
#21 |
nice! sounds cool... got any good contacts in alms right now?? *wink wink*. (I could use a good contact for a test or something.... haha)
![]() well, double clutching is just when you let out the clutch when you are in neutral during an upshift or downshift. It can be used in conjunction with heel-and-toeing, or not. For downshifting, it is best to use both at the same time, but it is possible to use one and not the other. so, this is how I view it: heel-and-toe - when you use your right foot on the brake and gas so you can simultaneously brake and blip the throttle on downshifts. rev-match - much similar to heel and toe, but can be done while left-foot-braking if the clutch is not needed for downshifts (ie. when a dog-box is used) double-clutch - engaging the clutch while in neutral when upshifting or downshifting. I consider them all to be entities upon themselves, although sometimes I do slip up say "double clutch" when I am talking about heel-and-toeing.
#22 |
I understand what you are saying. You simply break it down into 3 different peices where I view it as 2. Point is we understand what the other is talking about.
I know a few people here and there but mainly SVRA or FIA. I am not sure what you are looking to move into but with your record, which is impressive, have you thought about he Skip Barber driver search or something like it? I know RedBull has a excellent driver program. http://www.redbulldriversearch.com/ They are going to get a few drivers F1 tests. Not too shabby. I will keep my ears open and if I hear anything I can always PM you. |
#23 |
Since the thread headed in this direction, I figured I would comment on the Red Bull deal.
Colin Fleming used to wrench on our karts at Pitts in Van Nuys. Dominique Classens passed me a few times at Moran once, haha. If you have to be passed by a kid, its nice to know the kid is a pro formula racer in europe now. Now that Red Bull bought Jaguar F1, I think there is a good chance we'll see an american driver in F1 in the near future. Danny Sullivan is doing us proud. Sorry to have continued the hijack. Just a comment on hell-and-toe. If you find that you are just rolling your foot sideways, then you are going to have trouble keeping solid consistent brake pedal pressure. Forget touge and drifting, go to a real grip event and drive, you'll see what threshold braking is, and why you want your foot firmly planted on the brake pedal. The thing that completely fixed my heel/toe and improved my pedal control in every regard was to lift my feet off the floor. Seriously. Don't rest your heels on the floor of the car, lift them completely off, you'll heel/toe better, and your pedal work will improve dramatically. |
#24 | |
The RedBull idea is great, but the only set back is that I am Canadian... I doubt they'd be interested. Any help would be great though... so if you do hear of some sort of link, I'd be happy to hear it. thanks!
