This is a discussion on ENGINE TUNING DVD SERIES (Vol.1) by DRIFTING.com within the General Chat (DRIFTING Discussion/News and SITE Updates) forums, part of the General Forum category; Engine Tuning Engine Tuning DVD by DRIFTING.com Engine Tuning DVD RUN TIME; OVER 3 hours This Engine Tuning DOCUMENTARY shows ...
Engine Tuning
Engine Tuning DVD by DRIFTING.com Engine Tuning DVD RUN TIME; OVER 3 hours This Engine Tuning DOCUMENTARY shows how some of the basic features on the AEM EMS Software function while on the Dyno. DVD ORDER PAGE http://store.driftingshop.com/pentudvdaplp.html
DRIFTING.com @ FACEBOOK DRIFTING.com @ FACEBOOK DRIFTING.com @ TWITTER DRIFTING.com TWITTER DRIFTING.com STORE DRIFTING.com Tel.(877) 786-7694 The BEST WAY to reach DRIFTING.com is by calling between 11AM-5PM (PACIFIC STANDARD TIME) If you are on the EAST COAST then call at 2PM. If you reach our voicemail then CALL BACK AGAIN between 11AM-5PM (PACIFIC STANDARD TIME) |
Nice!!!! I like it!!
question
Is this with a SR engine or KA24DET?
I'd imagine you guys go into some of the math behind duty cycle ect so people with either engine can learn from this? Very interested in this DVD, is it exclusive to drifting.com?
ka-t :) org |
#4 | |
The main focus of the first DVD in the Engine Tuning Series is to show how to setup and operate the software. Drifting.com is currently the only company that is authorized to sell this DVD. thank you
When will this DVD be released?
we have been sitting on the raw content for a few months but we need to re-film the dyno section with a video capture.
the re-filming schedule has not been locked down, we might know more within 1-2 weeks
we have been getting several emails and calls about this DVD so we will do our best to post updates on this thread
-we plan to re-film near the end of July -the new version will been done with a video capture so the resolution is clearer The outline is done but more topics will be added after we apply the suggestions that have been submitted to us.
we are restating the objective again because this is asked a lot...
Vol. #1 will focus on how to operate the basic functions of the AEM EMS Software on the dyno
Any updates? Release date?
the content that we have can not be released
we are refilming within 1 or 2 hosts by either Sep-Oct or starting in January.
new update,
we might be able to lock this down by September, we will know more by tomorrow
Submitted Suggestions; By nutz @ SRT Forums
Opening the software Loading a base map (always start with AEM’s base) Setting up correct sensors for application Setting up injectors and fuel pressure Connecting to the ECU (can be difficult with obd-serial port) Uploading your map Setting the o2 gain (so gauge reads the same as the EMS sees) THE START UP (yea now were getting some where) Adjusting start up/warm up parameters Getting it to idle (just for basic tuning) Double check your timing/fuel maps (changes in sensors might make the map dangerous!!!) How to do baseline (non-boost) VE mapping for A/F (low load) (boost comp theory) predicting A/F load cells How to set up and interpret logs (very very important) Setting up o2 feed back Tuning load A/F Ignition timing tuning (dangerous subject) Knock sensor setup Setting up sensitivity for false knock How much to pull/add and how quick Putting it all together for drivability Throttle fuel correction Final idle adjustments Rev limiters/2 step Fan on –off ADVANCED Anti-lag theory and how to safely use it Traction control ???????? Injector phase theory and how to (changes for boost comp and cams) Staged injectors theory How to set up inputs/outputs
We are schedule to re-film next weekend
Re-filming takes place tomorrow
#15 |
over 3 hours of usable content was captured today
#16 |
the editor's copy will be completed by tomorrow so it can be sent out for review
#17 |
![]() http://store.driftingshop.com/pentudvdaplp.html ![]() http://store.driftingshop.com/pentudvdaplp.html ![]() http://store.driftingshop.com/pentudvdaplp.html ![]() http://store.driftingshop.com/pentudvdaplp.html ![]() http://store.driftingshop.com/pentudvdaplp.html
#18 |
I will most likely buy this. I'm building my engine real soon. Waiting on the machine shop.
ka-t :) org |
#19 |
the first 2 hours and 30 minutes have been reviewed,
so far so good
#20 |
Disc 1 out of 2 has been released as an "early copy"
http://store.driftingshop.com/vol1di1eco1h.html
#21 |
Disc #2 of Vol. 1 is schedule to be released by Monday.
#22 |
#23 |
We are getting calls each day about this DVD series so here are a few answers to our top questions;
1-What is "documented" in the 2 Disc Set? -Basic Template Setup -Data Logging to make fuel adjustments -Knock Sensor voltage readings -Introduction to Basic software setup 2-Does this DVD cover theory? NO, this documentary covers some of the basic operations of the AEM EMS Software 3-Disc 1? Disc 2? Vol #1?? I am confused??? Vol#1 has 2 Discs (Disc 1 + Disc 2) 4-Is this a manual? NO, this is a documentary that runs for about 3 hours and 30 minutes 5-Why did we produce this DVD? MANY customers who purchased our other titles called and requested that we produce a DVD that documents engine tuning 6-Does this DVD cover everything about tuning? NO, This is JUST Vol #1, which runs for over 3 hours. To cover most of the general areas we would need to release a few more volumes and the total run time for the series would be around 8 hours. 7-What are your future plans? Our plan is to talk to the customers who purchased to first Volume so we can outline the topics that will be documented in the next DVD.
#24 |
a new trailer will be released soon
#25 |
Does anyone have a universal AEM loom for sale for cheap....?lol I want a excuse to buy this DVD.
Does new computer software work on a old EMS? |
