Go Back   DRIFTING.com > General Forum > General Chat (DRIFTING Discussion/News and SITE Updates)
KIA's First Rear-Wheel-Drive Concept (3.3-liter turbocharged)
This is a discussion on KIA's First Rear-Wheel-Drive Concept (3.3-liter turbocharged) within the General Chat (DRIFTING Discussion/News and SITE Updates) forums, part of the General Forum category; KIA’s First Rear-Wheel-Drive Concept (3.3-liter turbocharged) http://www.prnewswire.com/news-relea...133993253.html...
Thread Tools Rating: Thread Rating: 35 votes, 5.00 average. Display Modes
Old 11-17-2011, 08:51 AM   #1
INFO
INFO's Avatar
DRIFTING.com @ FACEBOOK
DRIFTING.com @ TWITTER
DRIFTING.com TWITTER
Old 11-17-2011, 09:28 AM   #2
Cavi Mike
All any company needs to do is just take the small FWD car they already have and make it RWD. Why is that so frigging difficult?
Old 11-30-2011, 08:46 PM   #3
5150 Cruiser
are you talking about designing a new chassis and keeping the sheet metal, or just modifing an exhisting chasis and throwing a rear axle and drivetrain? Cause if thats the case, Maybe because it is difficult. In many cases it might be better to just start with a new platform/chassis. Which takes time.
5150 Cruiser is offline   Reply With Quote
Old 12-01-2011, 01:37 PM   #4
Cavi Mike
It doesn't take much to modify the floorpan of a car to accommodate the extra bits for a rear drivetrain, if any modification even needs to be done. Cars still have a tunnel down the center whether they're FWD or not. Bolt in a different rear sub-frame, turn the engine the right way and voila. The R&D involved is really not much. I'd buy a $17k Kia Koup in a heartbeat if it was RWD but a $30k Kia? Don't make me laugh.
Old 12-02-2011, 03:01 AM   #5
BigGameHit
Send a message via AIM to BigGameHit Send a message via MSN to BigGameHit Send a message via Yahoo to BigGameHit
very amusing indeed.
BigGameHit is offline   Reply With Quote
Old 12-02-2011, 09:03 PM   #6
5150 Cruiser
So that's it huh? Just turn the motor , bolt on a new sub frame with a differential and your done? Wow. Never knew it was that easy.
Unfortunately, it isn't. In most cases serious work needs to be done to accommodate a rear drive platform (especially one that intends to be mass sold) on a vehicle that never intended to have a longitude mounted engine. Just cause a car has a tunnel going down the center, doesn't mean its ready for a rear drive shaft either. And in most cases the rear floor pan would have to be completely ripped out to accommodate a rear differential.
If i ever win the lottery, perhaps one day I'll build one of these..
http://www.streetracersonline.com/articles/rs8/
I remember ford also sold a kit that included a front and rear sub frame that would accommodate a V8, as well as the drive train needed to make a focus rear drive. It wasn't cheap either. The kit alone was around 10K not including the engine and transmission. There was also alot of fabrication still needed. But still an interesting step in getting a compact car to rear drive.
Old 12-03-2011, 09:48 AM   #7
Cavi Mike
Completely ripped out? Ripped out of what? The car isn't built yet. I'm not talking about some random person doing this, I'm talking about this being done in an assembly line at a plant. You do know that cars are just spot-welded and glued pieces of stamped sheet-metal, right?
Old 12-03-2011, 10:12 AM   #8
5150 Cruiser
If its as easy and cheap as you say, then why don't manufactuers do it?
All i'm saying is that its not as simple as just thoughing a diff in the back and turning the motor sideways. If that were the case, then i'm sure we'd see alot more manufactuers go this route rather than designing a completely new car.
Old 12-04-2011, 09:11 AM   #9
Cavi Mike
Because it's easier and cheaper to produce FWD cars. That's common knowledge. The entire drivetrain can fit on a single pallet and be bolted in place with a handful of bolts. If you don't make anything except for cheap econo-boxes, it's the obvious choice of drivetrain. If you only make cheap econo-boxes, the choice is also obvious to not try to make a sports-car.
Tags
kia gt
