Go Back   DRIFTING.com > NEW to DRIFTING (BEGINNERS) > NEW to DRIFTING (BEGINNERS) Forum
Min Drift Speed
This is a discussion on Min Drift Speed within the NEW to DRIFTING (BEGINNERS) Forum forums, part of the NEW to DRIFTING (BEGINNERS) category; Hi experts, pls help me. What is a recommend minimum speed to start learning safely handbrake drifts? My country uses ...
Old 12-13-2007, 07:38 AM   #1
highflyers
Min Drift Speed
Hi experts,
My country uses km/hr. I see videos where u guys do it like 80 tp 100km/hr. goodness so fast
Old 12-13-2007, 07:48 AM   #2
cfrost
cfrost's Avatar
Stay in first gear when you start learning and begin with donuts
check this video out for some help:
Old 12-13-2007, 08:11 AM   #3
Soldat
There's a school here in the states called Drift 101. When I went, I spent the entire day inside a 50 foot x 50 foot square sliding around cones in first gear. I don't think I went over 10 or 15 mph all day and I learned a LOT.
It's better to start too slow you're first time and speed up a little bit the next than to start out too fast and hit something.
Soldat is offline   Reply With Quote
Old 12-13-2007, 12:55 PM   #4
piper1
nice how to vid without information over load
Old 12-14-2007, 01:58 PM   #5
atlantian
well, to start off from absolute scratch would be:
find a flat open area and just speed to 15mph about 20kmphr and pull the ebrake. repeat until you are completely comfortable with the sliding. you should not input throttle before you get used to the sliding sensation. it will scare the s out of you
Now you can practice dough nuts!
Old 12-14-2007, 02:34 PM   #6
cfrost
cfrost's Avatar
^cept remember that the ebrake isn't going to do anything unless you put in the clutch
(if you're in a rear-drive car)
Old 12-14-2007, 02:38 PM   #7
atlantian
yes, you have to clutch in too...
Old 12-14-2007, 02:43 PM   #8
Soldat
Sure it will.
*crunch, crunch, grind, snap*
