This is a discussion on Fox Body Mustang Drifting within the Pictures and Video Clips forums, part of the General Forum category; This very cool, it's like a full build thread. Can't wait to see more! I wish we had this kind ...
Thread Tools |
Rating:
Display Modes |
#26 |
Can't wait to see more! I wish we had this kind of traffic at Domestic Drifting.
1987 T/A-305 TPI/T5/3.42 SLP rear/Flowtech headers/Flowmaster 3inch exhaust/ Tokico Illuminas/Alston sfcs/TDS wonderbar/Edelbrock panhard bar/ Poly bushings The Domestic Drifting Forum |
#27 | |
if you dont mind me asking, what do you guys modify on them?
Floridaracing.org Tenative Schedule |
#28 |
jerm-
generally if you shorten the distance by cutting and welding from where the tie rod end mounts to the spindle will yield a faster turn and more angle.
Site Owner- Photographer Floridaracing.org www.floridaracing.org Editor - StangTV.com & DragZine.com 2011 Mustang - 597 RWHP 1965 Mustang - 1030 HP |
#29 |
Ive seen other ppl do that, but looking at sn95 spindes its rather impossbile cause if it foes any further out its just hitting the rotor
#30 | |
Once the rack become the limiter removing the rack spacers, and modifying the inner tie-rods is your next step. Only once you have done both of those should you have to modify the spindle/steer-arm. We are changing spindles in order to lower our car more, they will not add any steering angle.
Drift Mustang - 1990 Mustang GT turned Drift Machine |
#31 |
Update
New episode:
The car is now running 250lbs/in rear springs, 600lbs/in fronts, and 2" drop spindles. We are going to get back out the to track in a week.
#32 |
Did you have Eibach send you custom springs? I wanted to get thier prokit for my car, but it's not very low (not really important
) and not very stiff. I'd like about 250lbs or so for my cars rear, but the prokit is around 177lbs.
#33 |
We have coilovers on the car, so we are running 2.5 inch id linear springs on the front and 2.25 inch id liner springs on the rear.
I am under the impression that the prokits are non-linear springs so the rates are not a direct comparison. Also are you running a camaro? If this is the case, you will need different spring rates.
#34 |
Well, it's T/A but that's close enough
, ha. I'm currently running 618 in the front and about 175 in the rear. 250 or higher just seemed like something to work from. I know the Eibach drag kit for the camaro/firebird has one 217lb progressive rear spring and I've considered asking if I can just get two of those.Might just leave it until later anyway, it's likely we'll just go with weight jacks.
#35 |
why not just buy what you want and not buy a kit?
http://www.afabcorp.com/AFCO_Dynatec...ode=ct_Springs |
#36 |
what exactly are the race craft ones going to fix? I know they lower car but without really messing with the factory geometery, but they do acutally go beyond that?
#37 |
Actually the spindles don't lower the car, that's all in the coilovers. The spindles do help bring the front geometry closer to stock which helps the gain of camber in compression as well as helping reduce bump steer. The spindles also help move the area of travel within the shock's range to a higher and hopefully happier position.
-David |
#38 | |
Looks like we will be trying a slightly softer front spring, as the spindles have allowed us to raise our front roll center to a happier place.
#39 | |
Since we have coilovers on the car, we kept the ride height the same, but improved our geometry.
#40 | |
#41 |
What happened to the corolla? That's a big step from a corolla to a 'stang. Looks like a lot of fun though.
85 gts coupe |
#42 |
It's still around. Just time to drive something with some power.
#43 |
New Handbrake
#44 |
haha sweet e brake keep us updated
#45 |
We put together a website for the mustang buildup, www.drift50.com. The most recent work on the car was an install of an A/C delete and a HD power steering cooler.
We are getting ready for Just Drift Top Drift Battle on the on the 25th.
#46 |
Since Top Drift Battle is so soon, we had to do this one in hyper speed!!
#47 | |
it be hillarity on so many levels
#48 |
#49 |
Can't wait for El Toro.
#50 |
Sample One Time!!
Looks like a fun project, I almost started a fox body drifting project (85 SVO with the 4 banger turbo) but I ended up having to pull the drivetrain and ship it to my Uncle for his Ranger. Good luck with your project!! Keep up the good work.
