Go Back   DRIFTING.com > General Forum > Pictures and Video Clips
Fox Body Mustang Drifting
This is a discussion on Fox Body Mustang Drifting within the Pictures and Video Clips forums, part of the General Forum category; For all you old Mustang fans out there. The only mods to the car so far are Weight removal, Bilstein ...
Old 06-04-2007, 10:15 AM   #1
GBC
GBC's Avatar
Send a message via AIM to GBC
The only mods to the car so far are Weight removal, Bilstein Coilovers and an MM Panhard bar. Everything else it 100% stock. We are adding stiffer suspension and more steering angle next.
Drift Mustang - 1990 Mustang GT turned Drift Machine
GBC is offline   Reply With Quote
Old 06-04-2007, 01:32 PM   #2
toji004
toji004's Avatar
Send a message via AIM to toji004
interesting :$)
surferosa drift
toji004 is offline   Reply With Quote
Old 06-04-2007, 08:45 PM   #3
soultron
soultron's Avatar
Hot stuff, how much was it?
Old 06-04-2007, 10:30 PM   #4
Mars
Mars's Avatar
Send a message via AIM to Mars
sounds like something broke. SHoulda left the spoiler on there or used a coupe. GTs look hideous without them
Floridaracing.org Tenative Schedule
Mars is offline   Reply With Quote
Old 06-05-2007, 12:08 AM   #5
GBC
GBC's Avatar
That was one of our junkyard tires exploding.
Old 06-06-2007, 09:00 AM   #6
Ghost of Duluth
Sixgun
Ghost of Duluth's Avatar
Fun video, you spent more time in the dirt than my Jeep does.
Mustangs, old ones are not the easiest car to put sideways. The snap around on you very quickly, lot like an FD. Just poof and you are around. Hard to catch.
Old 06-09-2007, 11:52 AM   #7
Mars
Mars's Avatar
How are you going to go increase the steering angle? I know a lot of cars had rack limiters that you can pull out, but looking at the spindles there doesnt seem to be a lot you can do.
Old 06-09-2007, 10:24 PM   #8
GBC
GBC's Avatar
We are having a set of custom lower control arms built up. They are going to give us a significant increase in angle.
Right now the brake caliper is hitting the LCA long before we run out of steering lock. We are running a 1/8" wheel spacer up front with 17x8 30mm offset front wheels. I also did some clean up work on the spring pocket of the front subframe.
Old 06-11-2007, 11:07 AM   #9
GBC
GBC's Avatar
This past weekend at Willow Springs.
Old 06-11-2007, 01:25 PM   #10
soultron
soultron's Avatar
Now that's what I call drifting volume 1.
Old 06-13-2007, 09:48 PM   #11
DV19
DV19's Avatar
Wow... That reminds me of when our car was mostly stock... Keep up the good work. With enough parts and effort they make pretty good cars...
Good Luck,
DV
DV19 is offline   Reply With Quote
Old 06-14-2007, 12:41 AM   #12
GBC
GBC's Avatar
Got a sweet new exhaust on the car today. Still tame enough for street use and smog legal. Done a little different the your average 5.0 exhaust.
DV-
Yeah, we are running SN95 spindles and rearend, but there is some serious work that remains to get this little 5.0 working right. We should chat a bit at Sonoma, Seattle, or Irwindale. Driftlive should be at those events.
Old 06-14-2007, 01:24 AM   #13
Mars
Mars's Avatar
I thought about doing side exhaust on mine, but I wouldnt have much for ground clearance after having to have it clear the subframe connectors
Old 06-14-2007, 07:33 AM   #14
DV19
DV19's Avatar
Originally Posted by GBC View Post
DV-
We'll do..
When I ran side exhaust I ran oval shaped tubing... Dr Gas makes a kit that bolts in unless you know a shop that can make it for you from scratch. If you're in So. Cal. I have a guy that can do it for you.
HTH,
DV
Old 06-14-2007, 10:35 AM   #15
GBC
GBC's Avatar
I've used Dr Gas pipes in the past. They are quality pieces.
The tips that we have on the car now are resonators to keep the drone down a bit as we are still driving this car to the track. Once I get something to tow with, I think it will be time for some boom tubes.
Old 06-15-2007, 02:27 PM   #16
pwrslide
What changes were made from the first to second vid? Have you had the LCAs made yet?
pwrslide is offline   Reply With Quote
Old 06-17-2007, 03:59 PM   #17
d3p0
d3p0's Avatar
Between the two track events the only differences were the rear spring rate and the switch from moldy junkyard tires to somewhat newer (but still used) tires.
http://youtube.com/driftlive
Episode 3 was when we installed the new spring rate which made a significant effect on the handling in drift.
d3p0 is offline   Reply With Quote
Old 06-17-2007, 07:20 PM   #18
BenR
BenR's Avatar
Love the stang David.
BenR is offline   Reply With Quote
Old 06-17-2007, 08:51 PM   #19
GBC
GBC's Avatar
And by rear spring we mean front, the rear rates still need to be stepped up a bit.
Steering angle and lower ride height are on the way soon!!
Old 06-17-2007, 10:19 PM   #20
soultron
soultron's Avatar
Still badass for mostly stock.
1987 T/A-305 TPI/T5/3.42 SLP rear/Flowtech headers/Flowmaster 3inch exhaust/
Tokico Illuminas/Alston sfcs/TDS wonderbar/Edelbrock panhard bar/ Poly bushings
The Domestic Drifting Forum
Originally Posted by cfrost View Post
haaaaaaahahahaha soultron always wins
Old 06-20-2007, 11:54 AM   #21
Mars
Mars's Avatar
btw, how come you guys dont have subframe connectors welded up? I didnt see any in the video, those make a night and day difference in the car.
Old 06-20-2007, 02:12 PM   #22
DV19
DV19's Avatar
x2.... they made a huge difference in our car.....
Old 06-20-2007, 02:45 PM   #23
GBC
GBC's Avatar
We are going to do through the floor subframes, but not until after we get a cage in the car.
Old 06-23-2007, 06:15 PM   #24
GBC
GBC's Avatar
DV19,
it is my understanding that you run the racecraft spindle setup. How have those worked for you?
Old 06-23-2007, 09:14 PM   #25
DV19
DV19's Avatar
DV19,
No, we run stock Mustang spindles that we have modified ourselves...
I know that they have started to make some for roadracing applications that a few guys are R&Ding for them.... From what I've heard, they are nice pieces that appear to be strong enough for the task...
