Go Back   DRIFTING.com > General Forum > Pictures and Video Clips
SMALL BLOCK CHEVY 240SX BUILD (400 Cubic Inch/Carbed)
This is a discussion on SMALL BLOCK CHEVY 240SX BUILD (400 Cubic Inch/Carbed) within the Pictures and Video Clips forums, part of the General Forum category; I am 22 years old and my sex oblige has gone down to all but nothing. Sex with my boyfriend ...
Thread Tools Rating: Thread Rating: 70 votes, 5.00 average. Display Modes
Old 11-18-2008, 01:48 PM   #26
earlIsebella
Sex imply has gone down.
Sex with my boyfriend of 5 years has every been loving terrible and I possess every had an orgasm.
I habituated to to masturbate and dont coextensive with do that anymore. I dont infer from what's come to grief with me.
I habituated to to eternally seem to be like sex and now I look for ways to get out of it,
but the silver in my procreant zest is shaming my relationship.
Am I lacking vitamins or nutrients that counterfeit my sex push? What can I do to fix this problem?
http://www.rx-online-order.com/ - who's tried it?
Old 11-19-2008, 03:46 PM   #27
harmonirvin
Average time before ejaculation ?
What i would like to positive is how deficiency contact lasts for on ordinary formerly ejaculation.
All these junk comments from people long-term all Cimmerian dark i perfectly fire,
what i am looking for is comments by people on the bona fide world.
I deficiency to positive this so i can find out if i ejaculate prematurely. will can you help?
What from this it is wagerer for me to use?
http://www.rxvid.us
Old 11-20-2008, 09:16 AM   #28
markshatchi86
Send a message via AIM to markshatchi86
spam bots, yay!
Site Owner- Photographer
Floridaracing.org
www.floridaracing.org
Editor - StangTV.com & DragZine.com
2011 Mustang - 597 RWHP
1965 Mustang - 1030 HP
markshatchi86 is offline   Reply With Quote
Old 11-22-2008, 12:45 AM   #29
alanwoods
Look here
Look here: http://segmentman.com
Old 11-22-2008, 01:32 AM   #30
alanwoods
Look here
Old 11-26-2008, 06:24 PM   #31
KarrieTamsin
Any value in some soups?
I create a uncut knot of soups that check out terrific, and can be made in big batches and frozen.
Is there any interest?
Old 12-01-2008, 09:48 AM   #32
markshatchi86
why is this thread getting spammed so much
Floridaracing.org
Old 12-01-2008, 02:30 PM   #33
Justin Banner
Justin Banner's Avatar
Send a message via MSN to Justin Banner Send a message via Yahoo to Justin Banner
PM a mod yet? This has become rather annoying.
Also any updates?
Justin Banner is offline   Reply With Quote
Old 12-01-2008, 04:15 PM   #34
Mars
Mars's Avatar
Send a message via AIM to Mars
its cause you have a very large penis
Floridaracing.org Tenative Schedule
Mars is offline   Reply With Quote
Old 12-01-2008, 04:36 PM   #35
markshatchi86
Yah it is!
The motor and trans are at Mckinney Motorsports. They will start fabbing mounts on Wednesday. I will have updates then
Floridaracing.org
Old 12-03-2008, 02:58 PM   #36
i_drift_volvos
awesome! Is there that big of a weight difference even with the aluminum heads?
Old 12-04-2008, 08:23 PM   #37
markshatchi86
125-150 lb more then a KA
Floridaracing.org
Old 12-08-2008, 07:14 AM   #38
Checowa
Penis popper, almost done with yo rat rod?
Checowa is offline   Reply With Quote
Old 12-09-2008, 01:45 PM   #39
markshatchi86
Mckinney Motorsports was nice enough to find another small block to mock up with to keep mine as clean as possible. They started by modifying the pan to clear the cross member. About a 2x2 inch box had to be sectioned out of the back of the pan that I bought to allow for cross member clearance. Other than that, the whole center and rear part of the pan works perfect. As you can see, there is plenty of sway bar clearance. Some mild hammering in the tunnel allowed for the bell housing to fit and the motor sits back as far as possible without the distributor hitting.
The one problem they ran into was the size of the transmission. The TKO 600 is great that it uses a Muncie 4 speed transmission case for a 5 speed configuration; the bad part being that the actual transmission is shorter and sets the shifter about 4" further forward then the normal whole centerline, or about 1.5 inches completely out of the hole. There will be a shifter handle (as there is a million configurations) that will bend back further, though the shifter will come up in an unnatural location.
Using a T5 or T56 traditional 5-6 speed transmission will put the shifter in the stock location due to it's added length. Additionally, due to the tight tunnel clearances, it will require a hydraulic clutch release bearing for correct operation.
As you can see, the headers are going to be fun. Hooker was kind enough to send over 3 sets of their tightest fitting headers in search for a set that will require minimal modification. Also a remote oil filter may be used for added clearance for the headers
Floridaracing.org
Old 12-18-2008, 02:27 PM   #40
markshatchi86
Back from PRI and the mockup small block is sitting on it's own in the engine bay at Mckinney Motorsports. They might triangulate another mounting location for the block to cross member bracket. The transmission mount was a direct bolt on from another mount kit. Since the TKO 600 case is shorter than a traditional 5 speed, hence the cut back for the shifter. They are also going to mock up a T5 transmission and a few autos.
Headers on the passenger side will work fine, the drivers side just needs the bottom area where the flange is mounted to slightly clocked towards the left, giving room to run the pipes on the frame rail side of the steering shaft. Need to get a brake booster in there to check clearance on that back header tube, may need to be clocked or might be fine with just a heat shield.
Floridaracing.org
Old 12-18-2008, 05:09 PM   #41
Creizai
I see your chassis is rivited I remember back in the day everyone would talk about the pro's and con's. What made you decide to go that route and what rivits did you end up using?
Thanks .. looks different. I love 240s and I love rat rods. This could either kick *Censored**Censored**Censored* or suck *Censored**Censored**Censored*.
Old 12-18-2008, 10:54 PM   #42
markshatchi86
its a mock up engine bay, not a car yet
Floridaracing.org
Old 12-19-2008, 12:44 PM   #43
Justin Banner
Is it your car or is it just all mock ups to later be transferred to your car?
Old 12-19-2008, 02:24 PM   #44
markshatchi86
dont understand what your saying
mckinney has a mock up engine bay, thats where the R&D is happening.
Once the R&D is done, then Ill be putting my engine in my S13 with their mounting system
Floridaracing.org
Old 12-19-2008, 04:23 PM   #45
markshatchi86
modified pan, making a front sump pickup work on a rear sump oil pump, engine waiting for final mockup
Floridaracing.org
Old 12-19-2008, 04:55 PM   #46
Justin Banner
You liar! You really understood and answered my question.
Old 12-19-2008, 05:49 PM   #47
markshatchi86
haha
523 on motor, 702 on nitrous, only 10:1 compression, makes power to 6400, probably a 7000 RPM limiter. Makes 418 FT/TQ by 2500 RPM
Floridaracing.org
Old 01-05-2009, 05:32 PM   #48
markshatchi86
Here is a mockup of the final engine mounts. This is how they will come, but painted of course. Mckinney has also been working on a powerglide transmission mount which is now done. Additionally, they will work on T-56, T5, and Turbo type transmissions. For now, they support the glide, TKO series, muncie, and saganaw based transmissions.
They will be working on finishing up the headers this week and hopefully have the pan and pick up tube finished next week. The pan will need to be modified in the back to support a rear sump style pump, since the pan was originally designed for front sump pumps that are shorter. There is plenty of room in the back to drop the sheet metal of the pan down.
Floridaracing.org
Old 01-05-2009, 08:57 PM   #49
cheesy586
cheesy586's Avatar
Send a message via AIM to cheesy586 Send a message via MSN to cheesy586 Send a message via Yahoo to cheesy586
Nice work on the engine and the idea, hot man. I was wondering, how much is McKinney chargeing you for the custom motor mounts, and the cross member bracket, the whole custom fabrication?
cheesy586 is offline   Reply With Quote
Old 01-06-2009, 09:34 AM   #50
markshatchi86
crossmember is 100% stock and requires no modification, you can even run the stock sway bar.
The mount kit for the engine and trans costs $350, cheap.
Floridaracing.org
