DRIFTING.com SHIRTS
DRIFTING.com SHIRTS
DRIFTING.com SHIRTS
DRIFTING.com SHIRTS
DRIFTING.com SHIRTS
DRIFTING.com SHIRTS
Go Back   DRIFTING.com > General Forum > Pictures and Video Clips
SMALL BLOCK CHEVY 240SX BUILD (400 Cubic Inch/Carbed)
Thread Tools Rating: Thread Rating: 69 votes, 5.00 average. Display Modes
Old 02-04-2009, 06:29 PM   #76
markshatchi86
Send a message via AIM to markshatchi86
I have a single plane intake manifold and a nitrous plate on my motor so it sits pretty tall. I don't think it will fit with the nitrous plate on there but it MIGHT fit with it off.
If I had a lower profile dual plane, it wouldn't be an issue. Time will tell soon enough
Site Owner- Photographer
Floridaracing.org
www.floridaracing.org
www.myspace.com/timmah1
07 350z Enthusiast 343 WHP
72 datsun 510 350 WHP
www.floridaracing.org/510
91 240sx - 702 HP 400 CI
markshatchi86 is offline   Reply With Quote
Old 02-10-2009, 06:43 PM   #77
markshatchi86
The custom front sump oil pickup tube and pan is mounted on the small block. The bracket for the pickup tube had to be modified slightly to allow for proper clearance on the 3.75" stroke. The pan will hold over 8 quarts and has built in trap doors to keep the oil where it needs to be under cornering. There is also a rear sump drain bolt to allow for the oil around the oil pump to be drained.
The engine will be back over at the shop tomorrow where I will begin prepping it for front drive system and the SPEC clutch and flywheel to make way for the Quartermaster hydraulic release bearing.
Floridaracing.org
Old 02-12-2009, 09:29 AM   #78
markshatchi86
I installed the full serpentine drive system last night.
Floridaracing.org
Old 02-13-2009, 06:52 PM   #79
cheesy586
cheesy586's Avatar
Send a message via AIM to cheesy586 Send a message via MSN to cheesy586 Send a message via Yahoo to cheesy586
Nice man, good to see the project is coming along, so when do you expect the engine to be put in the car? I would love to see pictures.
cheesy586 is offline   Reply With Quote
Old 02-14-2009, 08:16 AM   #80
valve timing
wow.... that motor looks nice howmuch longer till its installed and running ?
valve timing is offline   Reply With Quote
Old 02-16-2009, 09:10 AM   #81
markshatchi86
I HOPE to put it in the next week, but I got to see on getting the time off.
If not, it won't be til the 2nd week of March
Floridaracing.org
Old 02-18-2009, 02:56 PM   #82
markshatchi86
With my travel schedule, March 16th is going to be the start day. Work til it runs. Between now and then I will be prepping the engine and transmission to get it ready.
Floridaracing.org
Old 02-18-2009, 08:47 PM   #83
markshatchi86
Progress on the Engine:
SPEC Aluminum flywheel and Stage 3 sprung clutch installed
Coolant temp Sensor in intake manifold installed
Holley Fuel Log installed
Distributor Re-TDCed, headers mocked up and 1/2 the distributor wires are made
Floridaracing.org
Old 02-19-2009, 01:20 AM   #84
valve timing
jesus that motor looks beautiful... how much longer til its in the car ?
Old 02-19-2009, 11:27 AM   #85
Piner
Piner's Avatar
those are some pretty interesting looking headers, i like them
http://e36driftbag.blogspot.com/
1998 BMW 328is S52 swap
Hold my Dragon!
www.nickelsgarage.com
Old 02-19-2009, 12:21 PM   #86
markshatchi86
3 weeks of march, confirmed.
Floridaracing.org
Old 03-04-2009, 10:25 AM   #87
nemesis91101
nemesis91101's Avatar
Send a message via MSN to nemesis91101
Wuda kept it nissan with a rb26 or an import with a 2jz or hell even a 13b-rew but thatll still be a mean 240 none the less good work. Post vidz on youtube of it and post the links I wanna see it in action.
If I were to put a haus of motor in my 240 it be either a vq35de, vk56de, or the new Vk37vhr :P
tndrift.com
nemesis91101 is offline   Reply With Quote
Old 03-04-2009, 02:36 PM   #88
Piner
Piner's Avatar
yeah but you're not, this setup is really sweet. It doesn't have the wireing hassles of any of those motors. They are more trouble than they are worth.
Hold my Dragon!
Old 03-04-2009, 02:50 PM   #89
nemesis91101
I'm not saying its not a sweet setup I'm jus not into hybrids 2jz's in toyotas rb's for nissans etc I'm not into swappin between manufacture engines that's all its just preference.
tndrift.com
Old 03-04-2009, 04:15 PM   #90
markshatchi86
I have never been one for building a 'typical' car, every car I have built is out of the box.
plus an RB or VQ isn't going to be making 400 ft/tq by 2000 RPM like my small block does.
Floridaracing.org
Old 03-04-2009, 04:26 PM   #91
nemesis91101
Oh I agree I'm not saying it won't it'll be sick I agree but but upload some vidz on youtube I'd like to see that beast roastin the tires. Btw are u doing anything to the rear end to handle the power? I read the short nose r200 can handle around 400hp give or take n the long nose off the 260z I believe can handle a lot more. What about any other chassis work?
tndrift.com
Old 03-04-2009, 05:34 PM   #92
markshatchi86
R200 will handle 800rwhp+ no problem, its the axles you have to worry about.
I have 80 feet of chromemoly sitting back here for a cage and plans for a FULL suspension build.
Floridaracing.org
Old 03-04-2009, 06:47 PM   #93
nemesis91101
Ah nice that's what I was thinking about yea there's a guy here with an rb25 that runs off propane. He snapped the stock axles I thnk they only hold around 400hp
tndrift.com
Old 03-06-2009, 05:47 PM   #94
fast_datsun
To go with the killer small blocks we have our new t56 trans mount kits done. Will be ready to ship in about 10-15 working days... Mack Mckinney
fast_datsun is offline   Reply With Quote
Old 03-08-2009, 06:38 PM   #95
markshatchi86
1 more week til the install!!!
Floridaracing.org
Old 03-08-2009, 06:54 PM   #96
killer406
killer406's Avatar
You are going to post up some video of it when it's done right? I'd love to hear what it sound like! 523 hp on the motor, that's awesome. And that torque curve! Nice!
killer406 is offline   Reply With Quote
Old 03-08-2009, 07:05 PM   #97
nemesis91101
Nice. Post pics of that thing sittin in there.
tndrift.com
Old 03-18-2009, 02:17 PM   #98
markshatchi86
Really busy, but here is what she looked like last night.
Floridaracing.org
Old 03-18-2009, 03:48 PM   #99
3rd_240
im actually hoping to get started on my own s13 coupe CSB swap... any way you can get me some information on those mounts??? ill be running a 350 out of a 71 nova in mine probably
3rd_240 is offline   Reply With Quote
Old 03-19-2009, 01:18 PM   #100
markshatchi86
www.mckinneymotorsports.com
Oil pan, pickup, and mounts for under $1000. Everything fit perfect, didn't even have to touch the power steering lines. Just a little tunnel hammering for the bigger bell housing
Floridaracing.org
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
