Can you drift a AUTOMATIC car???
  • Can you drift a AUTOMATIC car???
    Me and my friends are always arguing if you can drift in an automatic car! I wanted to know if any one could give a good answer thanks!
    Yes but it's only cool if you're in a 4-door sedan.
      Absolutely. Considering how many automatic cars you can shift these days, it is possible. Plus, all the weight transition techniques are the same. The only technique that I know you can't do is the shift lock technique since there's no clutch.
        I've never been much on the proper terminology of drifting but I think you meant you can't clutch kick. I learned on an automatic with an open differential and 70hp. It's the driver and the technique that makes drifting possible.
          Thanks!!!!!!!
            There's nothing stopping you from being able to. It's simply a matter of application of techniques and what you can and can't do with the configuration.
