2JZ 240SX SWAP DVD (By DRIFTING.com/2JZSwap.com)
Thread Tools Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
Old 12-14-2007, 05:12 PM   #1
INFO
INFO's Avatar
2JZ SWAP Teaser #1
2JZ SWAP Teaser #2
2JZ/1JZ SWAP PARTS LIST
2JZGTE MOTOR includes shipping & 6 month warrenty $2600
Transmission parts to piece together a r154 US Spec transmission from Toyota
Supra Turbo 1989 to 1992
1JZ Bell housing $375
1JZ flywheel $275
ACT clutch kit 650 FT torque 6 puck (option for our install) $700
SHIFTER EXTENSION PLUS CORE $250 + $200
2JZ SWAP KIT PLUS CORE $1500 +$200
2JZ PLUG N PLAY WIRING $450
CLUTCH LINE SS KIT $120
FUEL LINE KIT $130
A/C KIT (option for our install) $750
THROTTLE CABLE BTACKET $45
JDM 2JZ 3inch DOWN PIPE ADAPTER $100
WATER PUMP $150
TIMING BELT $28
SERPENTINE BELT $30 UNIVERSAL SPEEDOMETER INTERFACE $79.95
UNIVERSAL TACHOMETER INTERFACE $79.99
WALBRO FUEL PUMP $100
KOYO RADIATOR WITH UPPER INLET MODDED $450
SPAL FANS $200
FAN CONTROLLER $100
2JZ 4IN INTERCOOLER KIT $650
PULLEY SET W/P,P/S,ALT $135
MISC. PARTS HEATER HOSES, RAD HOSES, CLAMPS $275
Chapter Outline
Timing Belt
-Serpentine Belt Tensioner
-Crank Pulley
-Lower Timing Belt Cover
-Power Steering Bracket
-Top Dead Center (Check)
-Timing Belt Tensioner
-Idler
-Timing Belt
Water Pump
-Alternator (Move)
-Water Pump Bolts
-Hard Line Bolts
-Neck Bolts
-Upper Hoses
-Reused W/P Parts
-Clutch
-Pilot Bearing
-1JZ Flywheel
-Replace Throw-out Bearing
(Not Show)
-Pressure Plate
Transmission
-R154 Transmission
-1JZ Bell Housing
-Shifter Kit
-2JZ Starter
-Clutch Fork
-Slave Cylinder
Pre-wired Harness (Kit)
-Attach to Motor
2JZ Swap Crossmember
-Steering Rack
-Motor Mounts
-Rear Heater Hose
-Fuel Lines (Cut/Flared)
-Cutting & Flaring (Not Shown)
-Install Fuel Lines (Kit)
-Heater Hoses
-Heater Control Valve
-Power Wire Hole
-Bolt Crossmember
-Trans. Crossmember
-Driveshaft
-Control Arms
-Tie Rods
-Brackets
-TC Rods
-Sway Bar
-Downpipe
-Throttle Body
-Igniter Box
-Battery Wires
-Heater Hoses (Continued)
-Clutch Line
Fuel Lines (Continued)
-Pressure Line
-Return Line
Power Steering
-Return Line
-Steering Linkage
-Pressure Line
-Reservoir -Radiator (Kit)
-Intercooler (Kit)
-Dash Connector
-ECU, Attach Harness
-Attach Shifter
-Throttle Cable
-Heater Valve Cable
-Block Vacuum Port
-Install Dipstick
-Alternator Sub-harness
-Intake
-Fan Control Unit
Old 01-27-2012, 12:31 PM   #2
cristian116
2,600 engine trany or no trany
What comes with the engine for 2,600
cristian116 is offline   Reply With Quote
Old 01-27-2012, 12:35 PM   #3
INFO
INFO's Avatar
talk to Carlos for details
530-222-1555
http://tech2motorsports.com/contact.php
Old 09-14-2012, 09:32 AM   #4
Roderick12
Wow
I think that is a good way to repair your car. You should also record some videos of how to start drifting.
I mean to say that you should also publish some lessons dvd's about learnt drifting. because there are
many beginners who want that kind of stuff. Please tell me how I can order any DVD and also inform me
about the payment method.
Roderick12 is offline   Reply With Quote
Old 09-14-2012, 10:33 AM   #5
Cavi Mike
Here's your basic drift lesson. (YouTube "basic drift lesson")
Now go drift.
Tags
2jz 240sx swap, 2jz 240sx swap parts list, 2jz s13 240sx swap, 2jz s14 240sx swap, 2jz s14 240sx swap parts list
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
