HOW TO DRIFT (DVD's/Book)
Thread Tools Rating: Thread Rating: 43 votes, 5.00 average. Display Modes
Old 10-19-2008, 02:43 AM   #1
INFO
INFO's Avatar
How to Drift Book
http://store.driftingshop.com/howtodrbobyc.html
How to Drift DVD #1
http://store.driftingshop.com/driftbible.html
How to Drift DVD #2
http://store.driftingshop.com/drlinobyjdmo.html
How to Drift
By Wikipedia.com
Techniques for inducing drift
The basic driving techniques used in drifting are constant, though each car and driver will employ some subset of these techniques. A similarity for all drifting techniques is to be smooth and practice. These techniques include:[8]
How to Drift
Beginner techniques
These techniques do not use weight transition, so are typically the first thing the novice drifter learns.[9] However they are still used by the most experienced drifters, and require skill to execute properly. These techniques aim to induce a loss of traction on the rear wheels, either by locking the wheel (hand brake drift) or using enough power from the engine to break the traction force (power-oversteer and clutch kick).
How to Drift
Hand brake drift
While the clutch is depressed, the hand brake (or emergency brake) is pulled to induce rear traction loss. As soon as traction is lost, the driver releases the clutch, countersteers, and depresses the accelerator. This technique is used heavily in drift competitions to drift large corners, or to trim the car's line mid-drift.[10]
When learning to drift using this technique it is important to first countersteer and wait for the car to stop rotating and face the right direction to exit the corner, and only then to press the accelerator to give the car more gas to keep it sideways. If accelerator is pressed too soon or too much, the car will spin out.
How to Drift
Power oversteer or Powerslide
It is usually done at the corner exit by stepping on the gas hard, to slide side ways out of the corner. It is most commonly employed by beginners because it teaches steering and throttle control without the danger of an actual entry oriented drift.
In low-power cars power oversteer can be achieved by applying excessive amount of throttle at the end of a shift. As you are releasing the clutch during a shift, or immediately before that while the clutch is still depressed, press accelerator all the way to send more power to the rear wheels than is necessary for a smooth upshift. If done during a turn, the car will begin to slide. This technique can be used to initiate a drift at very low speeds in an underpowered car (e.g., when shifting from 1st to 2nd gear), and to enter in a higher gear while accelerating all the way up to the turn (e.g., accelerate in 2nd on the straight and shift into 3rd as you enter the turn).
The sequence of actions is as follows:
* Accelerate in the straight line leading to the turn.
* Turn the steering wheel to begin the turn.
* Clutch in.
* Shift to the next gear.
* Floor the accelerator.
* Clutch out.
* Wait for the car to go sideways, then countersteer and proceed to exit the corner.
Depending on how much power the car is making it is possible to keep the gas pedal floored from the shift throughout the entire drift, and in a low-power car this is often necessary.[citation needed]
Nissan 240SX Shift Lock Drifting
How to Drift
Shift lock (compression slide)
Initiated by downshifting (usually from third to second or fourth to third, and using a very fast shift) instead of braking, without rev-matching, causing the drive wheels to lock momentarily. Helpful for very tight corners, allowing the driver to approach the corner at a slower speed and lower revs, while allowing quick acceleration when exiting the corner. This technique can be very damaging to the engine if mis-used as the ECU is unable to rev limit when the engine is oversped by the rear wheels. Premature downshifters are called "Rod Stretchers".[11]
How to Drift
Clutch Kick
This is done by "kicking" the clutch (pushing in, then out, usually more than one time in a drift for adjustment in a very fast manner) to send a shock through the powertrain, upsetting the car's balance. This causes the rear wheels to slip. The foot should be at an angle (heel-toe) so the brake and gas may be pressed as well, this being needed to control speed and stop from spinning out in the drift.
Clutch kick can also be used during a drift to gain angle at the expense of speed. If the car is about to straighten itself out, kicking the clutch will cause it to rotate more. However since power delivery is interrupted while the clutch is depressed the car will lose some speed during the process.[citation needed]
How to Drift
Weight transition techniques
These techniques employ a further concept of weight transition. When a vehicle has the load towards the front, the back wheels have less grip than the front, causing an oversteer condition that can initiate a drift.
How to Drift
Braking drift
This drift is performed by braking into a corner, so that the car can transfer weight to the front. This is immediately followed by throttle, which in an RWD car causes the rear wheels to lose traction. FWD cars can also use this technique as it does not depend on the rear wheels being driven.[12] In FWD cars the front wheels are not allowed to lock due to the continuous power, the rear wheels locks easily due to weight transfer and due to the general front heavy design of FWDs. Good performance brake pads will help this technique.
How to Drift
Inertia (Feint) drift or Scandinavian flick
This is done by transferring the weight of car towards the outside of a turn by first turning away from the turn and then quickly turning back using the inertia of the rear of the car to swing into the desired drifting line. Sometimes the hand-brake will be applied while transferring the weight of the car towards the outside to lock the rear wheels and help the rear swing outwards. This type of drifting causes the car to accelerate faster afterwards, because of momentum built up while drifting. [13]
Note that the actual scandinavian flick maneuver in rally driving is more complex than feint drifting. In scandinavian flick the tires are intentionally locked by braking hard right after turning a little away from the corner. While the wheels are locked, the driver applies steering input into the corner, adds throttle while still braking and then rapidly releases the brake pedal. This causes the car to slingshot itself through the corner.
How to Drift
Kansei, Lift off, or Taking In
[14] - By letting off the accelerator while cornering at very high speeds, cars with relatively neutral handling will begin to slide, simply from the weight transfer resulting from engine braking. The drift is controlled afterwards by steering inputs from the driver and light pedal work, similar to the Braking drift.
How to Drift
Other techniques
How to Drift
Dirt drop
This is done by dropping the rear tires off the sealed road onto dirt, or whatever low-grip surface borders the road, to maintain or gain drift angle. Also colloquially called "Dirt Turbo".[15]
How to Drift
Choku-Dori/Manji (Pendulum)
Otherwise known as over-sway, this technique is done by swaying the car's weight back and forth on straightaways, using countersteer and throttle to maintain a large angle. This is a show maneuver that usually involves many cars following the same line. The car will be drifting straight and will be drifting side to side.
How to Drift
Text by wikihow.com
How to Drift
Drifting with Rear Wheel Drive and Manual Transmission
1. Find a car with both rear-wheel-drive and a manual transmission. Ideally it should be a sports car with as close to a 50/50 ratio as possible, and enough power to keep the tires spinning is ideal.
2. Head to an open area (i.e. an enclosed racetrack) safely free of pedestrians and motorists and police!
How to Drift
Hand brake technique:
1. Accelerate and shift into a gear with room to rev. Second gear is generally used because it allows the widest variance of speed and is best for harnessing the engine's torque.
2. Push in the clutch.
3. Flick the steering wheel to the inside of the turn as if you were going to turn around it. While simultaneously pulling the hand brake.
4. Immediately out some pressure on the gas pedal, let out the clutch, and steer the car in the direction of the slide, using throttle to control the angle of the drift.
More Throttle will make the car turn more, and also move the car away from the turn center. Less throttle will reduce angle, and allow the car to move towards the inside of the turn more freely. You're drifting!
Clutch Kick technique: Used while you are already moving to increase angle and/or revive wheel spin. While you are drifting, you may feel the car begin to lose its drift angle and power. If this happens, you can kick the clutch to attempt to revive to tires spinning speed. This is similar to powershifting, and you are in essence trying to 'chirp' the tires again and again.
1. Enter a drift.
2. while you still have the power put on, kick the clutch pedal in and out a few times as fast as you can until the car is drifting again.
3. end with your foot off of the pedal.
4. continue the drift, and when you feel the car begin to lose angle/power try to clutch kick again.
How to Drift
Drifting with Rear Wheel Drive Auto
1. Find a large, open area.
2. Accelerate to a speed of 20-30(depending on lot size and room)
3. Turn the wheel hard and floor it. You should feel the rear end slide around if this is done correctly. Only use full throttle to start the drift, after this you should use proper throttle control to continue through the corner.
How to Drift
Preparing to Drift with a Front Wheel Drive Car
1. Go to a large, open area.
2. Pull the handbrake or use the parking brake, riding it out the first time or two to get over your initial fear.
3. Set up a cone in the middle of the lot.
4. Drive up to it at speed (between 20 and 30 is desired).
5. Pull the hand brake and turn toward the cone. Immediately after you feel the back end come around, turn to the opposite direction. This is known as opposite lock.
6. Repeat the opposite lock at that speed until you can control your car well. Practice this for at least several weeks regularly until it becomes second nature. (Don't do this on roadways. It is dangerous to others and can get you fined.)
7. Slowly increase speed until you are proficient in a speed you are comfortable with. Get to know that speed--you should never drift above that speed unless you are practicing.
8. Upgrade. At the same initial speed, flick the steering wheel opposite of the turn and swing it all the way into toward the CONE (not turn, you aren't ready at this stage). As before, when you feel the rear end come around, go to opposite lock.
How to Drift
Drifting with a Front Wheel Drive Car
1. Approach a turn at a comfortable speed, preferably in mid 2nd gear.
2. Pull the handbrake while turning into the corner, try not to lock the rear wheels.
3. You should still have the power on, try not to go less than 1/2 throttle at any time during the drift.
- When you feel the car start to understeer, and lose angle, pul the ebrake harder. - When the car seems to turn too much, give it progressively more throttle, and release the handbrake some. -There is no textbook for drifting. You learn by doing it. -Don't tense up, just feel it.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
