Spark Plug threads SHOT!!!
This is a discussion on Spark Plug threads SHOT!!! within the TECH Discussion Forum forums, part of the TECH Discussion category; ok so i am just about ready to put my 240 on the road, i decideed to put in new ...
Old 11-18-2004, 06:24 PM   #1
Warped
Flippin nutball!!!!
Warped's Avatar
ok so i am just about ready to put my 240 on the road, i decideed to put in new spark plugs today. the # 1 & # 4 plug threads are all screwed up in the block! the plugs were titght coming out, whoever put them in was a moron! the plugs will go about half way before they stop turning. Is it possible to use a thread repair kit without having to pull the heads off? i'm concerned about pushing metal fragments into the pistons. Help before i take the motor apart!!!
Old 11-18-2004, 07:53 PM   #2
iownju
iownju's Avatar
Send a message via AIM to iownju Send a message via MSN to iownju
he only thing i can think of is take it a part because youll most liely get some small metal shavingsi cant think of anything else you could do besides maybe stuffing a rag or cloth down there then pull ut out somehow with the shavings. but thats all i got.
good luck
iownju is offline   Reply With Quote
Old 11-19-2004, 05:38 AM   #3
Warped
Flippin nutball!!!!
Warped's Avatar
yeah not sure if the rag thing will work. but i'll keep it in mind. thanks
Old 11-19-2004, 06:58 AM   #4
drift180
drift180's Avatar
i would try to get a new head if I were you. Shouldnt be too expensive for KA or SR heads. Cant think of anything else you could do. Rethreading would do it but I havent heard of a kit that does spark plug treads. Good luck with it.
drift180 is offline   Reply With Quote
Old 11-19-2004, 07:03 AM   #5
Warped
Flippin nutball!!!!
Warped's Avatar
there are a few heli-coil kits that are made to repair spark plug threads, i am on a tight budget as it is, and this is not something i had planned on having to fix.
Old 11-19-2004, 07:12 AM   #6
Ris4drift
if it was me id definately pull the head to be safe.
actually if it was me i would just shove them in there b/c im lazy. but if i was thinking correctly i would pull the head and see if its repairable.
Old 11-19-2004, 08:29 AM   #7
Warped
Flippin nutball!!!!
Warped's Avatar
just started to dismantle the motor, jessus this is going to be a pain in the a$$, even the timing chain has to come off. sometimes i miss working on chevy engines.
Old 11-21-2004, 02:52 PM   #8
Legit
Legit's Avatar
Send a message via AIM to Legit
If i were you id check your steering alignment.......Naw re-thread them.
Legit is offline   Reply With Quote
Old 11-21-2004, 03:03 PM   #9
Ris4drift
then just put a smallblock in your car :P
(seriously)
Old 11-21-2004, 03:44 PM   #10
Warped
Flippin nutball!!!!
Warped's Avatar
What in the hell are you talking about? well anyway i'm not pulling the heads. i got a thread chaser and i found a way to get any remaining metal off of the cylinders. Thanks anyway
Old 11-22-2004, 01:34 AM   #11
Legit
Legit's Avatar
I'm CrAzY. Thats what I'm talkin bout....I'm glad you got it sorted out! Cheers!
