Fixing E-Brake?
This is a discussion on Fixing E-Brake? within the TECH Discussion Forum forums, part of the TECH Discussion category; Well i got a 1984 toyota corolla sr5 and i swapped the rear end off a gts and put it ...
Old 11-21-2004, 07:29 PM   #1
FormulaDrifter
Corolla needs a swap!
FormulaDrifter's Avatar
Send a message via AIM to FormulaDrifter Send a message via Yahoo to FormulaDrifter
Fixing E-Brake?
Well i got a 1984 toyota corolla sr5 and i swapped the rear end off a gts and put it on the sr5...but one problem is that the ebrake doesnt work....a friend told me that all you need to do is take off the rear brakes and do some tightening and it should work....anybody got any info? thanks
FormulaDrifter is offline   Reply With Quote
Old 11-21-2004, 07:34 PM   #2
sdtouge
sdtouge's Avatar
do you have to pull the ebrake really high for it to work, or no ebrake at all?
Old 11-21-2004, 07:46 PM   #3
FormulaDrifter
no e brake
Old 11-22-2004, 01:36 AM   #4
Legit
Legit's Avatar
Send a message via AIM to Legit
Then either you have to tighten alot or your cable is messed up. The rear brakes work right?
Legit is offline   Reply With Quote
Old 11-22-2004, 07:29 PM   #5
FormulaDrifter
they should work...but they need fluid
Old 12-06-2004, 08:53 PM   #6
Legit
Legit's Avatar
yeah then check the cable.
Old 12-06-2004, 10:29 PM   #7
Monkey Garage
Monkey Garage's Avatar
I had a problem like that, but I had to pull it up ALL the way to get very little breaking. Just tightened the cable and it was fixed.
Monkey Garage is offline   Reply With Quote
