How to Increase S13 Shassis rigidity
This is a discussion on How to Increase S13 Shassis rigidity within the TECH Discussion Forum forums, part of the TECH Discussion category; I was concerned my shassis would flex during hard drifting. My old man is a machinist and can make stainless ...
Old 11-27-2004, 07:55 AM   #1
D1champ
D1champ's Avatar
I was concerned my shassis would flex during hard drifting. My old man is a machinist and can make stainless steel bars (any shape). Was wondering if this is do-able and which beams should be reinforced on the under carriage.
D1champ is offline   Reply With Quote
Old 11-27-2004, 08:30 AM   #2
SaintDrift
Midengine drift?
SaintDrift's Avatar
Just make a cage.
SaintDrift is offline   Reply With Quote
Old 11-27-2004, 08:58 AM   #3
D1champ
D1champ's Avatar
Originally posted by SaintDrift
Just make a cage.
I would but I still want to keep it relatively daily driveable.
Old 11-27-2004, 09:04 AM   #4
Valkyrie
Well, if you know how to weld and you're willing to go pyscho on your car, you can always do it like this:
http://www.club4ag.com/faq%20and%20t...ot%20Staff.htm
Strip the entire car and strengthen every freaking joint on the car, and you could probably weld on some steel bars to whatever part you want to make it stronger. You could probably remove weight at the same time.
Valkyrie is offline   Reply With Quote
Old 11-27-2004, 09:34 AM   #5
D1champ
D1champ's Avatar
That is what I was think about, maybe not that extreme but maybe welding on flat strands of 3" wide stainless about 1/8" thick. along the subframe. What do you guys think?
Old 11-27-2004, 12:04 PM   #6
GRiDRaceTech
GRiDRaceTech's Avatar
Have your dad fab up fender braces (see SPL's website for design), box and run a strengthening member between the tension rod mounts, create a triangulated rear strut tower brace (or tie the strut tower braces to the subframe mounts), run a rear crossbrace across the footwell, make a beefy front strut tower brace, and you should be well off. If you could integrate it, some sort of brace across the transmission tunnel would probably help, too.
Old 11-27-2004, 01:27 PM   #7
Ris4drift
i have a shell i was gonna learn to weld on , i was thinkign about just custom fabbing strut towers, cage, and maybe some jack rails for the side , but if you start addign stuff and are thiking about FD later on in life you might wanna make sure you dont go into stuff that could be considered tube frame mods.
Old 11-27-2004, 01:33 PM   #8
D1champ
D1champ's Avatar
I agree, I want to keep everything "behind the scenes", no roll cage for me. Fender braces seems like a good idea, anyone have design schematics for those spl parts??
