This is a discussion on Blacktop & Redtop, Same Block? within the TECH Discussion Forum forums, part of the TECH Discussion category; is a blacktop amd a red top block the same or not???? please amswer...
SHOP
yes
Oh Baby!
bascailly their both the same, only diff that ive read is that a black top is usually better at upgrading, but not by a huge noticable diff. i read the black top has stronger rods or something which makes it able to tune better or somethin. please correct me if im wrong.
now i dont know if im correct or not but im pretty sure that if the block has grooves in it then its a blacktop and if it doesnt than its a redtop. theres a pic below to show you what i mean.
hope that helps.. |
the blacktop has heatsink ridges on the front of the block and the redtop does not. The black top has oil squirters to cool the pistons. There are a lot of differences between the two but both are great engines. The s14 blacktop has variable valve timing but not the s13 blacktop.
#6 | |
kitchen fresh chicken
another difference between the 2....is that the blacktop cylinder heads were designed to breath a little better then the ones on the red top
SHOP
if you are reffering to a S13 Redtop and S13 Blacktop Sr20det bottom end
they are the same rods and pistons same part number all sr20det have cooling channels in the main bearings as for the heads only difference is early model S13 redtop motors did not have heatsink markings on the front of the head although late model S13 Sr20dets did use them |
#8 | |
To quote Bill sherwood
hey
thnks guys.. i have a blacktop block den cause i have all the things yall tellin me bout. but does that emna that i can used redtop [arts den? since they both da same?
please use english^
The blocks arent the same, only similar. All internals are very different, so more then likely you cant swap parts. Piston heads are different the crank shaft is different the conrods are different.
Well the S13 blacktop has ridges on the cylinder head not the block and s14 and s15 blacktops have variable valve timing other than that they are pretty much the same...
Tony Angelo
just soo were all on the same page are we talking about
a 4AGE motor or a Nissan SR20det S13 coz we got people talking about 4ag's and SR blocks
-Don't forget the struggle. Don't forget the streets- www.driftalliance.com www.clubloose.com Listen to Motley Crue |
it has to be a sr20 becuase um the diffenrnce between a red top 4ag and black top 4ag is ummmm a lot
#15 |
^-- It just occured to me..which fricken engine is this guy talking about? Im a 4a nut, so i instantly took it as the 4age.... but i see a lot of stuff abou the 240s
whoops?
#16 | |
#17 |
i believe redtops dont have oil squirters. I read somewhere that they dont. Someone correct me if I'm wrong.
Someother differences in the s13 and s14 sr20det is the s13 uses "low port" intake design and the s14 uses a "high port" design. Also the s14 has a bigger compressor than the s13 turbo. The differences between the s13 blacktop and redtop are very minimal. I would get the s14 blacktop over the s13 even though the price is higher. |
#18 |
they have oil squiters hell even the ka has oil squiters hell the Geo storm gt had a 4ag with oil squiters
#19 |
all turbo rwd sr's have oil squirters and the KA doesn't
