S13 Auto-manual issue
This is a discussion on S13 Auto-manual issue within the TECH Discussion Forum forums, part of the TECH Discussion category; Car 89 nissan 240sx Fastback/hatchback Conversion Auto-manual 95 pedals Motor Conversion SR20det Redtop S13 No abs, no hicas Base model ...
Old 12-12-2004, 10:16 PM   #1
nebrs13
Send a message via AIM to nebrs13
No abs, no hicas Base model no sunroof but had O/D
MAF S13 SOHC MAF
Exhuast 5zigen Rocket
manifold Stainless steel
Intercooler Side-top mount
Wiring for harness, srswap.com
Auto-manual wiring dont have any idea???
turbo elbow hks possibly
gauges Equuiss
boost gauge autometer
Stock height
stock SR
Problems, No ignition signal from auto-manual what needs to be bypassed for this?
i could possibly have wrong ECU with a E6
what wireing needs to be changed or bypassed for this swap
nebrs13 is offline   Reply With Quote
Old 12-13-2004, 02:36 PM   #2
nebrs13
unless i need to get a nuetral safety for a SR?
Old 12-23-2004, 04:31 PM   #3
driftcars
At the fuse box next to the battery, there is a two wire plug (probably the bottom one), connect those two wires together.
someone correct me if I am wrong.
driftcars is offline   Reply With Quote
Old 12-23-2004, 04:52 PM   #4
NismoSigma
Driftin' to the MOON!
NismoSigma's Avatar
Send a message via AIM to NismoSigma
What type of ECU you got?
NismoSigma is offline   Reply With Quote
Old 12-24-2004, 09:48 AM   #5
mechaniac
nuckin futs!
mechaniac's Avatar
feel underneath passenger side fuse box next to battery. There's a plug with two wires. One is grey, the other black. Cut them back far enough so you can connect them. Done.
