springs
This is a discussion on springs within the TECH Discussion Forum forums, part of the TECH Discussion category; sup peeps, ive just installed new springs, me and a friend installed them, we just took the old stock ones ...
Old 12-15-2004, 07:36 AM   #1
sideways ed
Send a message via AIM to sideways ed
springs
sup peeps, ive just installed new springs, me and a friend installed them, we just took the old stock ones off and replaced them w/ the new ones, it gave me a 2 inch drop, looks good and everything but today wen i was driving outta my driveway, i heard a noise and one of the screws that u screw the lugnut to fell off!!! i kno crazy, but the day before i was driving and i heard a noise as if the tire was gonna fall off, i checked the lugnuts and they were loose, is there any special way i had to install the springs??? im thinking that maybe that has to do w/ the gettin all lose and *Censored**Censored**Censored**Censored* , thanx to anyone for their suggestions, or opinions
sideways ed is offline   Reply With Quote
Old 12-15-2004, 09:38 AM   #2
drift180
drift180's Avatar
go to sears or another auto place and tell them to replace the stud. It might be that the stud was already damaged. if it happends again check if the spring is seated right on the shock. Also not a good idea to use aftermarket springs on stock springs.
drift180 is offline   Reply With Quote
Old 12-15-2004, 11:15 AM   #3
jaydm180sx
jaydm180sx's Avatar
Send a message via AIM to jaydm180sx
Re: springs
When you installed the new springs did you also upgrade your shock absorbers?
jaydm180sx is offline   Reply With Quote
Old 12-15-2004, 11:34 AM   #4
requiredoption
17 cycles per second
That was extreemly painful to my brain, just staring at that jibberish made me go cross-eyed.
I know that this gets beaten to death, but, come on, please at least try to present yourself with intelligible type.
requiredoption is offline   Reply With Quote
Old 12-15-2004, 12:45 PM   #5
FormulaDrifter
Corolla needs a swap!
FormulaDrifter's Avatar
Send a message via AIM to FormulaDrifter Send a message via Yahoo to FormulaDrifter
you probably forgot to tighten the lugs when you put the whell on...
FormulaDrifter is offline   Reply With Quote
