Sr20det Help!
This is a discussion on Sr20det Help! within the TECH Discussion Forum forums, part of the TECH Discussion category; OKay i got a 240sx withredtop sr20det and im having this idle problem....when i start the motor up it idles ...
Old 12-31-2004, 09:09 PM   #1
s13saru
Sr20det Help!
OKay i got a 240sx withredtop sr20det and im having this idle problem....when i start the motor up it idles perfectly at 750 rpm and stays constant, when i drive the motor down the street and come to a stop the idles act like they want to die but slowly regain its 750rpm constant. ITs not my vacuum hoses, and its not my Mafs cuz ive replaced it and still the same problem.... When i ran the ecu fault codes it says 12 and 34 which i guess is supposed to be MAFS and knock sensor but ive replaced them and the ecu is still reading 12 and 34.... ARE mY fault codes correct?Ive checked my Throttle position sensor but im not sure whats the specs on the resistance, voltage. etc... if anyone has some INFO IT WOULD GREATLY BE APPRECIATED!
s13saru is offline   Reply With Quote
Old 01-01-2005, 11:00 AM   #2
NeveR
Sounds like a vac or boost leak to me.
Check your Intercooler piping for leaks.
NeveR is offline   Reply With Quote
Old 01-04-2005, 07:17 PM   #3
2501
Send a message via AIM to 2501
I thought intercoolers were only on turbo'd engines. An Sr20DET is NA.
2501 is offline   Reply With Quote
Old 01-04-2005, 08:10 PM   #4
s13saru
naw dude sr20det IS TURBO! PEACE! car is running perfect.... no need for this thread anymore.....
Old 01-04-2005, 11:14 PM   #5
rlngtngku
rlngtngku's Avatar
Send a message via AIM to rlngtngku
LOLOL best post ever.
rlngtngku is offline   Reply With Quote
Old 01-05-2005, 03:48 AM   #6
2501
lol I dont know anything about JDM engines.
Old 01-05-2005, 08:29 AM   #7
DriftGirl
HighSider
DriftGirl's Avatar
SR20DET
DriftGirl is offline   Reply With Quote
