3" exhaust on my 240.... (help)
This is a discussion on 3" exhaust on my 240.... (help) within the TECH Discussion Forum forums, part of the TECH Discussion category; I was thinking about putting 3" exhaust on my stock 1997 240sx cept I don't know if it will work ...
Old 12-31-2004, 11:09 PM   #1
Dc2TyP3R
Dc2TyP3R's Avatar
Send a message via AIM to Dc2TyP3R
I was thinking about putting 3" exhaust on my stock 1997 240sx cept I don't know if it will work for the 240 I forgot what they called it because it was stock like there wasn't gunna be enough air flow or pressure or something but if it is possible where can I get the parts and what are all the parts that I need to put 3" exhaust on my 240
Dc2TyP3R is offline   Reply With Quote
Old 01-01-2005, 01:01 AM   #2
raemi
Send a message via AIM to raemi
a 3" exhaust on your car will cause in a lack of back pressure. it wont really help you on the low end but at the top end it will give you a little bit more power. the best thing to add to your car to make a 3" exhaust efficient is a turbo.
raemi is offline   Reply With Quote
Old 01-01-2005, 02:56 PM   #3
UberSpeed
UberSpeed's Avatar
that thing you are talking about it back pressure. It supposedly (or maybe its been proven) gives the motor more torque. If you plan on adding a turbo or SR20DET in the near future, just get a new intake and maybe a cheaper or no exaust. Once you get a turbo system or motor, the turbine will deliver plenty of back pressure, so then a 3 incher would be grand.
However if you just wanna keep it NA, stick wit a 2.5 or 2.75 inch exaust
UberSpeed is offline   Reply With Quote
Old 01-01-2005, 05:47 PM   #4
Dc2TyP3R
Dc2TyP3R's Avatar
SO if I did an SR20DET swap it will give enough back pressure to run a 3" exhaust with any problems?
Old 01-01-2005, 06:10 PM   #5
GRiDRaceTech
GRiDRaceTech's Avatar
Both Raemi and Uberspeed should not have posted. Their information is incorrect.
A proper 3" exhaust on the KADE will give gains throughout the rev range, not just up high. An increase of 8-12whp isn't uncommon.
3" is ok for an SR swap.
Old 01-01-2005, 06:42 PM   #6
raemi
can i see dyno sheets on this?
Old 01-01-2005, 07:34 PM   #7
GRiDRaceTech
Yes, you can.
Post number 14.
http://www.zilvia.net/f/showthread.p...t=exhaust+dyno
Old 01-01-2005, 09:43 PM   #8
raemi
Yes, you can.
Post number 14.
thanks but i want a dyno sheet of a 60mm exhaust to compare it to as well (if possible).
Old 01-02-2005, 12:11 AM   #9
GRiDRaceTech
It just so happens I have one of those too.
(Dyno done by S14DB on Zilvia.net)
Old 01-02-2005, 03:16 AM   #10
Ris4drift
what a n00b post.
i love you, tell andy to get my stuff
Old 01-15-2005, 09:12 PM   #11
Chachi
Chachi's Avatar
I put a 3" on my KA and it had more power all around, I didnt lose any power I could feel but I did feel that it was faster, more than I would expect from just adding an exhaust
Chachi is offline   Reply With Quote
