92' 240SX Suspension setup?
This is a discussion on 92' 240SX Suspension setup? within the TECH Discussion Forum forums, part of the TECH Discussion category; I am interested in doing road course this spring/summer, I was wondering what would be a good spring, shock/strut combo ...
Old 01-08-2005, 03:10 AM   #1
sidewaysS13
sidewaysS13's Avatar
Send a message via AIM to sidewaysS13
Suspenion Set up
I am interested in doing road course this spring/summer, I was wondering what would be a good spring, shock/strut combo for a 92' 240SX Coupe. Also how hard is it to a 300zx brake conversion?
sidewaysS13 is offline   Reply With Quote
Old 01-08-2005, 09:07 AM   #2
LOVMUFN
Drift Assoc. - Lead Tech
LOVMUFN's Avatar
KYB Gas struts are great my friend has them on his S14. I would go with some good springs like Eibach or RS*R. Make sure you get a performance spring and not a lowering 'dress up' spring.
Brake conversion is EASY, it bolts right up... as long as you have a 5-lug conversion too. You should also get the master cylindar to get the propper fluid movement.
Old 01-08-2005, 09:31 AM   #3
NeveR
Save your money for a full coilover set-up as opposed to a spring & shock combo.
If you're gonna do your suspension, do it right the first time.
NeveR is offline   Reply With Quote
Old 01-08-2005, 10:16 AM   #4
GRiDRaceTech
GRiDRaceTech's Avatar
Since you asked for a spring/strut combo, I will respect your wishes.
RSR Race springs plus KYB AGXs.
MUFN is right. The brake conversion is straightforward, and the master cylinder is extremely highly recommended.
Don't forget that if you don't upgrade to grippier tires, there's practically no point in having bigger brakes.
