Owner of SC300 and need help
This is a discussion on Owner of SC300 and need help within the TECH Discussion Forum forums, part of the TECH Discussion category; I am a proud owner of a 94' Lexus SC300 with everything stock, but replaces the suspension and put on ...
Old 01-10-2005, 05:46 PM   #1
Stanleys FAT
Stanleys FAT's Avatar
Send a message via AIM to Stanleys FAT
Unhappy Owner of SC300 and need help
I am a proud owner of a 94' Lexus SC300 with everything stock, but replaces the suspension and put on a body kit, also some rims, but the question that always have been bothering me is that if i get the common JZ engine swap, then should i rather go for the 1JZ or for the 2JZ??
Stanleys FAT is offline   Reply With Quote
Old 01-10-2005, 07:41 PM   #2
techtrix
techtrix's Avatar
2jz
techtrix is offline   Reply With Quote
Old 01-10-2005, 10:48 PM   #3
kaitokid21
the sc300 comes w/ a 2jz in it already (basically the supra motor w/o turbos) i believe turbonetics makes a bolt on kit for this car?
kaitokid21 is offline   Reply With Quote
Old 01-11-2005, 12:39 PM   #4
tonesdef
Send a message via AIM to tonesdef
Ask your self how much power do you want to make and would you rather have a high reving motor. If you just want like 400 horses stay with the na 2jz and just turbo it. The 2jz swap isn't cheap and finding a full clip is about 5-6k. A 1jz is cool and i nice motor for drifting becuase it likes to rev and gets there fairly quick other than that its a *Censored**Censored**Censored**Censored**Censored* to find parts for if something breaks your looking at a month or two of down time.
tonesdef is offline   Reply With Quote
Old 01-11-2005, 12:46 PM   #5
CRASHDRIVE
CRASHDRIVE's Avatar
http://www.driftgirl.org/
Ms. Emerald can probably answer some of your Q's
(it's okay, there's no shame on asking a girl about car questions :P )
Old 01-11-2005, 01:55 PM   #6
Stanleys FAT
I would stick with the N/A 2JZ and finding maintanance parts are no problem for a 2JZ GTE cause you can get it at your local toyota dealership, but thats the problem, a 2JZ-GTE gives you more HP output and its easier to find parts, but the 1JZ i'm still curious if dealerships carry parts for the 1JZ and also is it more reliable than the 2JZ.
Old 01-11-2005, 04:26 PM   #7
DriftGirl
HighSider
DriftGirl's Avatar
Thank you CRASHDRIVE
The TT 2jz is king, bigger, stronger, faster, etc...period
The NA version is not just stripped of turbos. its not the same internal make-up :
You could get the correct pistons (they are not he same in turbo and NA supras), do sum hole punchin, etc, etc and make a 'Supra Motor' but after all that...you couldve paid for the real deal.
Id do it in this order:
- USDM spec supra TT motor
- JDM Supra TT (ditch the crappy jdm turbos)
- Add a turbo 'kit' to your current car-
- 1jz
And Your not gonna find many parts for the 1jz stateside. A lot of people see the cheaper priced 1jz, but dont think about whats involved with installing and maintaining said engine.
Save a bit more and do the 2jz or boost your engine and have cash to get LSD and suspension
DriftGirl is offline   Reply With Quote
