Changing LSD gear oil on 240SX?
This is a discussion on Changing LSD gear oil on 240SX? within the TECH Discussion Forum forums, part of the TECH Discussion category; if I need to change the gear oil inside the diff, do I have to take the whole diff out? ...
Old 01-11-2005, 02:20 PM   #1
sk8kei
Question about changing LSD gear oil on 240sx
if I need to change the gear oil inside the diff, do I have to take the whole diff out? I know that's a drain plug close to the bottom, but how can I fill in a new gear oil into the diff(which I don't have to take out the diff out) I notice that it has a small hole on the top of the diff, but how can I drink the oil in from there?
sk8kei is offline   Reply With Quote
Old 01-11-2005, 11:04 PM   #2
GRiDRaceTech
GRiDRaceTech's Avatar
I don't recommend drinking the diff fluid.
You pull the bottom plug and let it all run out. Then, you fill it up from the side (with a squeeze bottle or a suction pump) until the fluid is level with the hole. Close 'er up and you're set.
