S13- Power door lock
This is a discussion on S13- Power door lock within the TECH Discussion Forum forums, part of the TECH Discussion category; Has anyone had problems with the driver side door cylinder not locking/unlocking? The key will not turn in either direction. ...
Old 01-18-2005, 01:13 PM   #1
Aiki-Drift
Aiki-Drift's Avatar
Question S13- Power door lock
Has anyone had problems with the driver side door cylinder not locking/unlocking? The key will not turn in either direction. I stopped cause I didn't want the key to snap. The inside latch is kinda stiff but works. Now I have to go thru the passenger side and unlock the door from the inside. Wazup?
Aiki-Drift is offline   Reply With Quote
Old 01-18-2005, 02:02 PM   #2
GRiDRaceTech
GRiDRaceTech's Avatar
I had the same problem. Then I took out the driver's lock cylinder and taped up the hole. What happened was that the resistance spring's mounting tabs broke off and the lock cylinder just spun freely.
I'm too cheap to replace the lock.
Old 01-18-2005, 06:23 PM   #3
Aiki-Drift
Aiki-Drift's Avatar
No man. My key will not turn or budge in the slightest. Could it be like a solenoid or something behind the door?
Old 01-19-2005, 01:05 AM   #4
GRiDRaceTech
Maybe your spring got jammed? Take the door apart and have a look-see.
