Fuel Filter and 300ZX
This is a discussion on Fuel Filter and 300ZX within the TECH Discussion Forum forums, part of the TECH Discussion category; I heard that you can replace the fuel filter with some sort of other fuel filter and it increases the ...
Old 01-23-2005, 08:10 PM   #1
sidewaysS13
sidewaysS13's Avatar
Send a message via AIM to sidewaysS13
I heard that you can replace the fuel filter with some sort of other fuel filter and it increases the horsepower...also what parts will swap over from the 300ZX to the 240SX other than the brake kit?
sidewaysS13 is offline   Reply With Quote
Old 01-23-2005, 09:21 PM   #2
GRiDRaceTech
GRiDRaceTech's Avatar
No, a fuel filter switch WILL NOT increase horsepower. You can replace the 240SX's fuel filter with a Z32 300ZX's... I'm not really sure why, but that's what I have on my S13.
Old 01-23-2005, 10:11 PM   #3
sdtouge
sdtouge's Avatar
hey grid do you know fi the 300xz fpr will work on the s13? i figure it would do the job better than stock when i upgrade my pump, and its 50 dollars cheaper than most aftermarket ones. i dont know how i came up with the idea of this working but that i think it would because the nismo one is universal (pretty much) so its a strech but i think it might work
other things you can take from a z
clutch (redrill for sr20)
brakes
5 lug hubs
t3 turbos if you want
wheels for when you do your 5 lug swap
obviously brakes
brake master cylinder
you could use anything you wanted if you had the money
Old 01-24-2005, 12:47 PM   #4
C2POWERHAUS (H)
C2POWERHAUS (H)'s Avatar
You could also use the fuel pump when you add more horsepower, but most people with 240's tend to go with the walbro fuel pump (unless you find a z32 at the junkyard. Then its just cheaper to use a z32 fuel pump)
C2POWERHAUS (H) is offline   Reply With Quote
