This is a discussion on S15 SR20 & 6-Speed into S14? within the TECH Discussion Forum forums, part of the TECH Discussion category; im pretty new to nissan. just doing my research before i sell my honda. my question is: does the 6speed ...
my question is: does the 6speed tranny with the sr20 found in an s15 mate into a usdm s14? i imagine all sr20s are the same and therefore they wouldn't have any problems putting one under the hood of an s14, but what about the 6speed tranny? i want to put a complete s15 engine/tranny into a kouki s14. SHARE WITH ME PEOPLE! let me know whats up. |
get the s14 motor, its cheaper. dont waste your money on the weaker 6spd trans of the s15. just my .02
the S15 6 speed is the weakest box to ever come in a silvia from experience (we now use an RB25DET box in the car). Unless you're after the awesome power of VVT
then go for an older S14 engine with an S13 box, which seems to be the strongest of the bunch, although I dunno what you guys got over there in the US.
ok
well i am only looking for 300whp max. anyone have the specs on the s15? s14? i dont know the hp for either from the factory. |
the 6 speed is the same one that is one trhe 350z. lol. yes its weaker but plenty strong for 300 hp. but find outs wich is cheaper, s14 sr motorset and a extra s15 tranny, or just a s15 motor set.
if you have a s14 you cant just switch trannys, you need to switch bell housings, then it will work, so put the s15 gears in the s14 bell housing and it will work. |
comin from a honda background (I'm assuming you owned a FWD) shouldn't you worry about gettin used to a RWD nissan first before gettin into all this engine and gearbox swapping jazz?
im trying to do a pricelist to fig out what will cost less. a wrx or s14 built to my prefferences. yes i own a FF, but that doesnt mean i dont own a FR as well
![]() the bellhousing is seperate from the tranny right? then it should be like legos. |
#8 | |
I'd like to think that the car that's better suited to its application from the factory is the best base to start with and will cost you less in the long run. |
What do you want an SR20 for they sound like lawnmowers, go for the RB20/25 then youll know the sound of true brilliance.
yeah, jump on the bandwagon and install an RB in your silvia... for drift use.... on a budget...
Oh Baby!
if u wana do sometihn crazy, turbo the ka and drift a sports car with a turbo truck engine!!! even though i wouldnt do it
Lets Enjoy Car Tuning!
hahaha, this is a bad idea
just be reaaaally original and dump the motor out of this monster in there!
3 cylinders of pure POWER!! lol!
I just got an email from a guy who wants to put an SR in a 350Z. if you want to be different, try one of these
put a perioxide & ammonia turbine and drift that SHI AT its weighs 35lbs and produces 1400hp. perfect for weight disp.
#15 |
Is there a reason you want the S15 motor over the S14 or the non-VVT S13 engines?
