This is a discussion on Need ECU Tech Support within the TECH Discussion Forum forums, part of the TECH Discussion category; Does anybody know which wire is the Speed Sensor to the ECU on the Harness where it plugs into the ...
Does anybody know which wire is the Speed Sensor to the ECU on the Harness where it plugs into the ECU in the kick panel on the '96 240SX SE
? Any help provided would be greatly appreciated. If you know, you can contact me at topgun_2012@yahoo.com. Thanks.Problem Solved. Same Wiring pattern from '91 ECU. Yellow(w/ green stripe) wire 8th in from the top( as mounted ) in the center row. Haven't really pushed my '96 to the limit yet, just pushed it enough to know the speed sensor is clueless. ( Went just off Speedo, somewhere around 122~125, Speed normally cuts off at ~118 )
| Tags |
| ecu tech support |
