88' Supra MKIII (MA70) swap
This is a discussion on 88' Supra MKIII (MA70) swap within the TECH Discussion Forum forums, part of the TECH Discussion category; sorry if this is a dumb question to any of you... i know the 88`Toyota Supra MA70 came with the ...
Old 12-28-2003, 09:46 PM   #1
CTAD
Send a message via AIM to CTAD
i know the 88`Toyota Supra MA70 came with the 7M-GTE engine here in america, and i was wondering if it was possible to swap the 1JZ-GTE engine from the 90'-93 MA70 into the 88' supra
CTAD is offline   Reply With Quote
Old 12-28-2003, 10:48 PM   #2
sidebyslide
Touge Specialist
sidebyslide's Avatar
yes
sidebyslide is offline   Reply With Quote
Old 12-29-2003, 01:37 PM   #3
ACDSupra7
ACDSevenGuy
ACDSupra7's Avatar
RE:
Very common. You can ask Coiloverkid, I know he did the full swap.
Old 12-30-2003, 04:29 AM   #4
emission
Moderator
emission's Avatar
If you plan on doing the swap go for a second gen 1JZ-GTE. Toyota had the first gen 1JZ recalled kept blowing the turbo's.
You can swap the motor into an 88+ supra any chassis under 88+ needs to be swap'd to fit ( 88+ on ). Why? the motor sits off balance with older cross members. You also need 2jz powersteering lines and 2jz throttle cable in order for this to work correctly.
Old 12-30-2003, 08:20 AM   #5
driftfreak
just remember 2jz=3.0L 1jz=2.5L
oh an a friend of mine has a 1jz for same....shameless plug for him
