Advantages of V-Mount Intercooler?
This is a discussion on Advantages of V-Mount Intercooler? within the TECH Discussion Forum forums, part of the TECH Discussion category; whats the overall greater advantage of VMIC other then it being more protected from drift related intercooler damage? according to ...
Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Old 12-29-2003, 09:42 PM   #1
sidebyslide
Touge Specialist
sidebyslide's Avatar
whats the overall greater advantage of VMIC other then it being more protected from drift related intercooler damage? according to the intercooler article featuring the Signal/Endless RX-7 it says "optimum cooling" however v-mounts are closer to the engine bay and have less contact with air. unless the air is scooped upward from the airdam.
sidebyslide is offline   Reply With Quote
Old 12-29-2003, 09:45 PM   #2
driftfreak
umm...well the IC is has less pipeing so it will have better thrttle responce..and it wont block the raidaitor and such..sorry bout the bad spelling...
Old 12-30-2003, 07:11 AM   #3
CrazyHawaiian
Sample One Time!!
CrazyHawaiian's Avatar
He's right, the shorter piping causes less pressure drop meaning boost is more responsive. I think the main advantage of the engine bay VMIC setup's your talking about is the IC is cooled from both ends. At the bottom end, the air flowing through the front dam and over the radiator is directed up into the IC. At the top end of the IC, the hood vents are directing air onto the top of the IC. Air hitting it on both sides makes it cool better than a front mount design which is only being cooled from one side. Thats my understanding anyway ...
Old 12-30-2003, 08:12 AM   #4
Ghost of Duluth
Sixgun
Ghost of Duluth's Avatar
Actually from what I understand it's cooled better because you are splitting them up more and swapping them. In a front mount set up, the air passes throught the intercooler first which heats it. Then it's warmer as it passes through the radiator. Not much space between them to cool them down plus you break air flow. In a V-mount setup, the air passes through the Radiator first then has a nice long space to travel before hitting the Ic. This allows the air to cool down more. Plus the angle is different in a V-mount set up too. If i'm not mistaken with a stock radiator and a fmic on a 240, both units are vertical to the ground. With a v-mount, it makes the air path form a j, air comes in the front, up the chute and out the hood vents. Makes air pass faster and more efficient. Same on the FD. Only diff is the FD already has the radiator mounted at an angle stock.
I could be dead asz wrong but that's my take on it.
Old 12-30-2003, 02:49 PM   #5
ArchangelX
Send a message via ICQ to ArchangelX Send a message via AIM to ArchangelX
Hmm..I've seen it installed in many different ways. I suppose that means there's differen ways of thinking.
Ghost, this setup is more about what you're explaining...where you can pretty much see how it' forms that J with the difusor plate at the top of the Koyo radiator that air passes before then over through the intercooler and vented out behind the hood vents.
But then you've got HKS and Knightsports and their way of doing it, which is where I understood the V-Mount got it's name. I think in a true V-mount they're positioned like a V so that both the radiator AND the intercooler gets more air distributed equally across the surface provided.
Otherwise, I think they woulda called it a J-Mount, ya know what I'm saying? Whatever works best for your car...do it.
ArchangelX is offline   Reply With Quote
Old 12-30-2003, 04:04 PM   #6
Ghost of Duluth
Sixgun
Heh I meant the air formed a j. Entered in at the bottom and shot up out the top. but yea the photo is what I was talking about.
They ought to call it a Jamount. Thats my name. Then it would be a "My" mount.
Old 12-30-2003, 10:16 PM   #7
sidebyslide
Touge Specialist
i thought V-Mount was vertical mount?
Old 12-30-2003, 10:44 PM   #8
TokiEvolution
TokiEvolution's Avatar
Im not sure but i think its because when u have a big IC, not much air gets to the radiator right? so i guess its better for cars thet run hard and over heat faster then when cold air is hiting the radiator. thats what i think the V-mont is for. if u think im wrong just think about how the air moves when the IC is in front of the radiator it kinda looks like this (=) air cant move thru the IC as easy so if it can, the air moves from a high presser area to a low presser area (so it gos around the IC) on a V-mont the air hits both radiator and IC cold air for the part that needs it the most? right? (sorry for the bad spelling )
TokiEvolution is offline   Reply With Quote
Old 12-31-2003, 02:00 AM   #9
Chas
Chas's Avatar
Air thats heated from the intercooler is not going through the raditor. It improves cooling, turbo response, and total cooling effecientcy.
Old 12-31-2003, 12:26 PM   #10
mranlet
mranlet's Avatar
does this not question?
Cooling, Response.
Old 12-31-2003, 01:06 PM   #11
Sideways_In_SD
Exclamation ARCHIVE THIS THREAD PLEASE.
Nah, it's like the picture archangel posted. Tilted-over Vee.
V-Mount is v-mount. Verticle mount is stock.
Driftfreak, Crazy, and Ghost all got it. Just like what Chas said, when they're sandwiched the radiator gets warmed I/C air.
Old 12-31-2003, 03:11 PM   #12
Ghost of Duluth
Sixgun
Three virgins for me for getting it woot
Old 01-01-2004, 04:56 AM   #13
Sideways_In_SD
Talking HEY!!! HANDS OFF...
Those virgins are mine!!! Keep your grubby paws off you dirty fack!!!
Old 01-01-2004, 05:25 AM   #14
ArchangelX
LOL...
Ya....the V-Mount is really important for cars like the RX7..before the radiator would just overheat and fry the Intercooler...it doesn't do much for either's cooling factors.
I know the RX7 is just nothing but a huge heat producer, oil gets burned quickly in an FD, gotta check it every week or so...at least I do. I remember the first time I shut it down and went to open the hood..my gawd....I could fry meat on it!!!
Old 01-01-2004, 11:42 AM   #15
JuN GDB
Touge Special!
JuN GDB's Avatar
can you do v-mounts in the new wrx sti since the engine is placed pretty far back like the rx-7
JuN GDB is offline   Reply With Quote
Old 01-01-2004, 11:47 AM   #16
ArchangelX
Any more questions?
http://www.superstreetonline.com/fea...s/130_0304_jun
Only problem I see is that this is a heavily modified WRX. I have a 02' WRX, and yes...there's a ton of room in the front for it. I'm sure it's very possible. Just have to figure out which one.
For more info, I suggest you check out the NASIOC Forums:
http://forums.nasioc.com/forums/index.php?s=
Do a search and you'll have probably some more info than what I just gave you..it's bound to have been asked already.
Old 01-02-2004, 03:36 PM   #17
Ichi-Go
Chas please approve.
Ichi-Go's Avatar
I have a ?, and I think you all can help me. Well number 1 is the intercooler, number 3 is the radiator. but is number 2 the AC heat exchanger thing. If it is that is so cool v-mount turbo while retaining AC.
Ichi-Go is offline   Reply With Quote
Old 01-02-2004, 03:37 PM   #18
Ichi-Go
Ichi-Go's Avatar
another
Old 01-02-2004, 03:38 PM   #19
Ichi-Go
Ichi-Go's Avatar
two more...
Old 01-02-2004, 03:39 PM   #20
Ichi-Go
Ichi-Go's Avatar
Last one and it is way to big for a oil cooler it is probably AC.
Old 01-03-2004, 02:39 PM   #21
Sideways_In_SD
Lightbulb It's an A/C Condenser...
That's a pretty trick configuration I like it.
And I'd say that's an "E" mount configuration, but I just pulled that outta my a$$.
Question, who fabricated all of that for you and....why don't you know what's under you hood?
Nice tho
Old 01-03-2004, 03:48 PM   #22
Ichi-Go
Ichi-Go's Avatar
Sideways thats not my car... I wish. but i like the sound of e-mount sounds cool. i got it off some japanese site, i could'nt read the writing though. Thanks for the replies but doesnt it cool like AC.
Old 01-03-2004, 03:50 PM   #23
Ichi-Go
Ichi-Go's Avatar
Here's the web site i got it off hope it helps.
http://www.kameson.com/RX-7/intercooler3.htm
Old 01-03-2004, 08:57 PM   #24
Sideways_In_SD
What are you talking about??
It's actually still a V mount, not an E like I made up. Once I had a chance to look at the site you were looking at, I had a better idea. There's a few applications where they kept the A/C on the car. So they threw the A/C condensor on top of the radiator. They're all different pics of a few different cars with V mounts done to them.
Lates
Old 01-04-2004, 09:13 AM   #25
Ichi-Go
Ichi-Go's Avatar
MY bad that was a typo i meant doesnt it look like AC sorry about the confusion. Keeping AC is sweet i would think with the v mount the condenser would'nt hurt your cooling that bad and your AC would work better because the air would be cooler(not going through the intercooler first.
Tags
advantage of v-mount intercooler, v-mount intercooler
