TRD springs info Ae86
This is a discussion on TRD springs info Ae86 within the TECH Discussion Forum forums, part of the TECH Discussion category; need info on the spring rates of these springs: TRD part# 00602-48130-001 their site doesnt have info and i'd like ...
Old 03-28-2005, 08:03 PM   #1
etxxz
their site doesnt have info and i'd like to know if this things are enough to start drifting...i'll get shocks later when my pockets heal
I got my 86 in the shop under 20v surgery to come out of it this weekend... SR5 w/ welded diff, i been practicing in it for 6months with a 40hp 4ac engine (2pistons missfired and sometimes they didnt!)
etxxz is offline   Reply With Quote
Old 03-28-2005, 11:07 PM   #2
O5m0515
Those are nasty springs. That code is for the progressive TRD spring which is the same spring as the Eibach Pro-Kit springs. Really soft and not worth it.
O5m0515 is offline   Reply With Quote
Old 03-29-2005, 05:50 AM   #3
etxxz
yes they are progressive, but wouln't they be hard once i start sliding?
the thing is i can get them for $150 new....and they worth $280+
but if you say they're soft should i even get em to drift on?
Old 03-29-2005, 08:25 AM   #4
cfrost
cfrost's Avatar
Don't bother buying them, they're useless. Get some TRD Linear springs, if you have a car setup mostly for track, get 8k front and 6k rear. If you have a street car I recommend something like 6.5 front 5.7 rear
Go with what you're comfortable with, but if you want to drift, do not get progressive springs, too much body roll.
This guy can help you out with getting some GOOD TRD springs, his name is Max
http://forums.club4ag.com/topic.asp?TOPIC_ID=97337
Old 03-30-2005, 10:44 PM   #5
SidewaysGts
SidewaysGts's Avatar
do not get linear springs, too much body roll.
So your saying to get progressive instead?
Old 03-31-2005, 09:26 PM   #6
O5m0515
He mistyped obvously. Get linear springs, not progressive.
Old 04-01-2005, 08:56 AM   #7
illegalgarage
for beginers use 6.0 kg up front
4.7 kg in the rear
also does pretty well on the street
want to get a little bit more wild get 8.0 front and 6.0 or 6.5 rears
you have to use the right shocks as well
I run 12 kg fronts 10 kg rears for my daily driver
hahahaha
Max
illegalgarage is offline   Reply With Quote
Old 04-02-2005, 12:57 PM   #8
SidewaysGts
They -really- need sarcasm tags
Old 04-03-2005, 09:11 AM   #9
etxxz
alright...this means i gotta spend $300 on springs. f***
i'm going for either 6/4.7 or 8/6 and later on i'll put some shocks.
Thanks a lot guys
btw for those who dont know my 86 is coming outa 20v surgery this week!
Old 04-03-2005, 11:36 AM   #10
zerodrifter
zerodrifter's Avatar
Send a message via AIM to zerodrifter
hahahaha
What car are you running those on?
zerodrifter is offline   Reply With Quote
Old 04-03-2005, 10:23 PM   #11
illegalgarage
87 GTS coupe
Max
Old 04-05-2005, 07:56 PM   #12
marshun
stop spreading disinfo
www.technotoytuning.com get those instead
they make coilovers and you can get'em in whatever spring rate you want.
Old 05-13-2005, 07:29 AM   #13
etxxz
Guys, what TRD part are these:
48131-ae801-80 (8.0kg/mm front?)
48231-ae801-70 (7.0kg/mm rear?)
7.0 rear seem waaay to stiff for intermidiate skill drifting? i'm way past the beginer stage and far from any pro/advanced...only have ~ 6months burning tires
