SR20DET Help ASAP!
This is a discussion on SR20DET Help ASAP! within the TECH Discussion Forum forums, part of the TECH Discussion category; Me and my friend are installing his sr20det motor into his '93 240sx hatch and we need to know if ...
Old 03-29-2005, 11:51 AM   #1
flmaster36
SR20DET Help ASAP!
Me and my friend are installing his sr20det motor into his '93 240sx hatch and we need to know if anyone knows of any diagrams on the vacuum lines because we are a little confused and want to make sure we are doing this right....We want to have it in and running by thursday the 31st because that is the first day the track opens and he is wanting to run it...SO ANY KIND OF HELP WOULD BE APPRECIATED.THX.
flmaster36 is offline   Reply With Quote
Old 03-29-2005, 04:45 PM   #2
Stannyboy
Stannyboy's Avatar
vac lines.. hmm take the nipple from the cold pipe and connect it to the waste gate. if you have a boost controller then the unit hooks up in between that. On the Throttle body side top left is for fuel pressure reg. The top right is for recirculating the blow off. the bottom one is for the carbon can. I took that out since i don't need it that can be capped. hope this helps you guys. its only 3 lines you have to hook up. good luck
Old 03-29-2005, 08:37 PM   #3
flmaster36
Thanks man, thats what we needed to know.
