This is a discussion on tuning for 270-300 whp Questions within the TECH Discussion Forum forums, part of the TECH Discussion category; hey watsup? im going to be starting an s14 project as soon as i get back to the states in ...
hey watsup?
im going to be starting an s14 project as soon as i get back to the states in june. im starting my research and i have a couple questions. from the start i plan on using a completely stock s14blacktop. my question is, if i upgrade the turbo,manifold,injectors,fuelpump, and add a fmic, what are my best options for tuning? can i get away with a FPR and a boost controller and maybe a couple hours on a dyno? i have noticed the apexi FC. kinda expensive. anyone have any experiance with it? like the title says, my goal is around 270-300 whp. i plan on using 550cc and a gt25r along with the necessities. thanks for any direction. |
even with the numbers your shooting for not way high i would recommend getting a F con or a greddy e manage ment system more tuning capabilites and who knows u may get even more out of it then what your expecting
i would also say ditch the VVT-i it can actually cause u to lose power Last edited by D1 DRIFTER; 04-05-2005 at 10:26 PM. |
#3 | |
I would recommend the Apexi PFC, if not that, then I'd suggest an apexi SAFCII, PFC is the best bet though. I've played with that system quite a few times, very easy to use. |
you'll definitely need a larger MAF Sensor from a Z32 or Q45. the stock ECU won't read that, so you'll need some form of piggyback FMU for sure.
Alot of people have used the Apexi S-AFC 2 because of it's ease of use and price. i believe the Greddy profec e-01 is even better, and has more features as well as upgradability. |
#5 | |
Got a date with Lady Luck
#6 | |
Fuel Pump Z32 300ZX MAFS 550cc injectors SAFC FMIC Profec B boost controller Dyno tune for like 1.1 Bar of boost. Keep the T28, its good for at least 300 RWHP. You'll need SAFC (or similar... though SAFC is easiest to tune imo) to read the different MAFS and also to sdjust the fuel curve for the 550cc injectors (stock are 370cc). |
