KA24DE Timing Chain Replacement
This is a discussion on KA24DE Timing Chain Replacement within the TECH Discussion Forum forums, part of the TECH Discussion category; I am changing my timing chain. I am at the point were i just have to take the bottom front ...
Old 04-18-2005, 02:36 PM   #1
DOHC240drifter
I am changing my timing chain. I am at the point were i just have to take the bottom front cover off to take the timing chain out. When i took off the sproket i marked the cams position put i forgot to mark the sproket. I have a book and it told me to set the pully to 0, but it doesnt have numbers just the nail lookin thing on the block and like little teeth on the middle pully. My question is can i just set the timing to a standard position? or what could i do so when i put the timing chain on i can have correct timing? Thanks guys.
DOHC240drifter is offline   Reply With Quote
Old 04-20-2005, 10:47 AM   #2
GotNismo?
But officer i swear....
GotNismo?'s Avatar
clyde? dude is that u
Old 04-23-2005, 02:49 PM   #3
Nismo241
Send a message via AIM to Nismo241
Timing is easy, dont go by marks on the chain, go by marks on the crank pulley and the key ways on the cam gears, you set the crank to TDC, which is the second mark on the crank from the left, line it up with the "nail looking thing". Then set the cam gears to where they need to be(can't remember off the top of my head where that was anymore). The rest is in your book.
Nismo241 is offline   Reply With Quote
Tags
ka24de timing chain, ka24de timing chain replacement
