My S14/Stitch Welding 101
This is a discussion on My S14/Stitch Welding 101 within the TECH Discussion Forum forums, part of the TECH Discussion category; While the motor is being built i figured Id do as much to the car as possible......all the sound deadening ...
Old 04-25-2005, 06:42 AM   #1
driftdeez
driftdeez's Avatar
While the motor is being built i figured Id do as much to the car as possible......all the sound deadening material and carpeting are gone.....Been stripping the car down to bare metal for the past month scraping, sanding, cutting etc........I finally towed it to my work this Friday and stitch welded every seam with spot welds exaclty one inch apart from each other(factory seams are held together only with seam sealer(putty)......did the whole interior, around the strut towers, and underneath the fenders........welding the seams adds a considerable amount of rigidity to the chassis.
Any suggestions on what color to paint the floorboard? I was thinking black and then silver on each of the spot welds.
Rear Wheel Well....
Rear Lower Seat area(RH)
Brace under Drivers Seat.....
Rear Lower Seat are(LH)
Full Interior Shot.....
Rear Upper Seat....
Rear Wheel Well....
Lower Door Jamb....
Passengers Seat Brace....
Drivers Floorboard by Pedals....
driftdeez is offline   Reply With Quote
Old 04-25-2005, 11:21 AM   #2
sdtouge
sdtouge's Avatar
wow that looks good,
quick question how come you chose to fo the spot or tack welds (not shure what there cald) instead of welding the enitre part where they meet then griding it down later with a grinder?
are you mgona make a roll cage as well?
Old 04-25-2005, 11:35 AM   #3
driftdeez
driftdeez's Avatar
well I have a cusco 6 pt bolt in cage, but I was thinking of going all out and getting a real cage with an x in the back and the door impact bars. Thers really no need to weld the whole seam. Tack welding is more than enough.....anything else is too time consuming and if done improperly, can actually warp the chassis.
Old 04-25-2005, 02:15 PM   #4
Driftin180sx
Controlled KAOS
Driftin180sx's Avatar
Send a message via AIM to Driftin180sx
Looks good i did teh same thing to my S13 it is fun for mw for some reason.
Driftin180sx is offline   Reply With Quote
Old 04-27-2005, 09:13 AM   #5
driftdeez
driftdeez's Avatar
it really wasnt that bad.....its just the car has been down for so long it seems like an eternity
Old 04-27-2005, 09:51 AM   #6
illegalgarage
You use wire flux?
or shielding gas?
I like stich welding better my self, but you did a good job there and it looks fine
Max
illegalgarage is offline   Reply With Quote
