Here we go again, fc idle prollems
This is a discussion on Here we go again, fc idle prollems within the TECH Discussion Forum forums, part of the TECH Discussion category; i blew my alternator belt on my fc and after i replaced it i noticed that the belt i replaced ...
Old 05-04-2005, 09:34 AM   #1
GotNismo?
But officer i swear....
GotNismo?'s Avatar
i blew my alternator belt on my fc and after i replaced it i noticed that the belt i replaced ti with it alot shorter. now the car idles at 3000 rpm as oposed to 750. could the belt have anything to do with it? or could i just need to reset my ecu.
Old 05-04-2005, 09:39 AM   #2
kumasan616
...belt length shouldn't have anything to do with idling, check to make sure everything is connected properly, something could be disconnected/loose...
kumasan616 is offline   Reply With Quote
Old 05-04-2005, 03:32 PM   #3
theflatlander
theflatlander's Avatar
are you talking about right when u start it up or does it idle at 3k when it's at operating temp? check for vac. leaks, sounds like the problem.
Old 05-05-2005, 09:08 AM   #4
GotNismo?
GotNismo?'s Avatar
yea at op. temp. it idles a lil under 3000, idk it varies. today it was idleing at 2.... could the fact that the first time i started it after reseting the ecu the hood was off? extra air? or maybe a throttle cable stuck.... imma check
Old 05-13-2005, 02:40 PM   #5
SpeedMachine
SpeedMachine's Avatar
Sounds like you either bumped the TPS out of whack, or the rod to your OMP is stuck on something. It happens alot when working around the alternator. Check those things and you should find your trouble.
SpeedMachine is offline   Reply With Quote
