Compression Question
This is a discussion on Compression Question within the TECH Discussion Forum forums, part of the TECH Discussion category; Hi guys, I was just wondering if having lower compression on a ka without turboing it will make it loose ...
Old 05-12-2005, 10:25 PM   #1
FC3slider88
FC3slider88's Avatar
Send a message via AIM to FC3slider88
Hi guys, I was just wondering if having lower compression on a ka without turboing it will make it loose a lot of horsepower? My ka blew and I found a really great deal on a ka that has only 50,000 miles. It was rebuilt with lower compression rods, pistons, and bearings and a polished head. The seller says it has 8.9:1. compression. Will this have a lot less power than a stock ka24de.
Thanks, Alex
FC3slider88 is offline   Reply With Quote
Old 05-12-2005, 10:53 PM   #2
insane
...are you?
insane's Avatar
The stock ratio for the ka24de is 9.5:1 as far as the difference in power the engine you want to buy will have 2 percent less horsepower than a stock N/A ka24de(assuming they have the same amount of miles)
insane is offline   Reply With Quote
Old 05-13-2005, 09:27 AM   #3
FC3slider88
Ok, well my old stock one had like 117,000 miles so maybe this one is probably about the same power even though it is lower compression because it is new and rebuilt.
Old 05-17-2005, 06:44 PM   #4
GotNismo?
But officer i swear....
GotNismo?'s Avatar
possibly built for turbo?
Old 05-17-2005, 10:24 PM   #5
FC3slider88
Yeah, it was originally intended to be turbo
Old 05-18-2005, 08:33 AM   #6
TIREKILLER
That engine would probably be a dog across the entire rev band, but the place you will notice it most is in the throtle response. If your gonna get that engine look into getting a turbo kit at the same time. Or find another engine.
TIREKILLER is offline   Reply With Quote
Old 05-18-2005, 11:42 AM   #7
FC3slider88
You mean the response will be better or worse?
Old 05-18-2005, 11:58 AM   #8
TIREKILLER
Worse of course. You will have less cylinder pressure with a lower static compression ratio. In other words less force pushing down on the piston. The engine will feel lazy.
