8kg front 7kg rear springs too much for Ae86?
This is a discussion on 8kg front 7kg rear springs too much for Ae86? within the TECH Discussion Forum forums, part of the TECH Discussion category; front: 48131-ae801-80 (8.0kg/mm) rear: 48231-ae801-70 (7.0kg/mm) does 7.0 rear seem waaay to stiff for intermidiate skill drifting? i'm way past ...
Old 05-14-2005, 06:09 AM   #1
etxxz
does 7.0 rear seem waaay to stiff for intermidiate skill drifting? i'm way past the beginer stage and far from any pro/advanced...only have ~ 6months burning tires
any thoughts appreciated
etxxz is offline   Reply With Quote
Old 05-18-2005, 04:03 AM   #2
etxxz
b.u.m.p.
Old 05-18-2005, 05:00 PM   #3
O5m0515
IMO 8/6 is nice but if you want 8/6.5 would push the rear out a little easier. I've only driven 6/4.7 and 8/6 at the track at multiple drift events but never tried 8/6.5 so thats just speculation. I think that 7 might be too stiff.
O5m0515 is offline   Reply With Quote
Old 05-18-2005, 05:14 PM   #4
Aiki-Drift
Aiki-Drift's Avatar
This was originally posted by Alex Pfeiffer and the link is below
BlackTruenoAE86,
4 front, 6 rear kg springs are really bad. You need to get some 8 kg springs for the front of that thing. I would suggest going short stroke and coil overs all at once, with some RCA's. NCRCA's would be best. Once you get your shocks, springs, rca, lateral rod taken care of, then go for some 4 links. You will be amaised at the gains
http://www.drifting.com/forums/showt...&page=36&pp=15
Hope that helps at least a bit.
Aiki-Drift is offline   Reply With Quote
