auto to manu tranny swap...help
This is a discussion on auto to manu tranny swap...help within the TECH Discussion Forum forums, part of the TECH Discussion category; Okay...this is what I got: a SOHC 240sx motor with manu tranny and ecu. I currently have a DOHC motor ...
Old 05-15-2005, 11:24 PM   #1
sidewaysS13
sidewaysS13's Avatar
Send a message via AIM to sidewaysS13
Okay...this is what I got: a SOHC 240sx motor with manu tranny and ecu. I currently have a DOHC motor with auto tranny. I have never done a swap. I was wondering if anyone has and if they could provide me with a list of parts that I would need to get this done. I've got the manu tranny off the SOHC motor, and every thing seems to be okay so far. I am replacing the clutch with a stage 2 clutch and lightend flywheel, and a short shifter.
I figure this is what I need, please fill in:
Slave cylinder
pedal set
cables
driveline
and I'm blank from there...
again any and all help is thanked for in advance...
sidewaysS13 is offline   Reply With Quote
Old 05-16-2005, 08:03 AM   #2
sdtouge
sdtouge's Avatar
you also will need a slave cylinder, and to cut a small hole in the firewall i believe. then you can use your stock ecu so you have a higher speed cut etc.
you also will need a pilot bearing to put inside the flywheel i beleive too.
good luck.
also, do a search under 240sxforums.com/forums for 5 speed swap or soemthing liek that.
Old 05-16-2005, 09:37 AM   #3
GotNismo?
But officer i swear....
GotNismo?'s Avatar
a new master cylinder may be required too.. i think so the pedal actually has something to compress. i could be wrong. check out if your master has a series of wires or bars on the firewall where the clutch pedal should be. if not id say you have to get a new one. again i could be wrong.
