This is a discussion on can't take key out when turbo timer is on within the TECH Discussion Forum forums, part of the TECH Discussion category; I recently bought a GReddy Fullb Auto turbo timer. the unit works so when u goto turn the engine off ...
sleeping in traffic
the unit works so when u goto turn the engine off it kicks in but as u go to take the key out it won't let u, pressing the key release button dose nothing. The car in question is a 92 nissan silvia S13 full import from japan to australia. When i went to install the unit suprisingly there was already a plug n play adapter fitted. Now the handbrake (ebrake) sensor is fitted, and the instructions say that there is a grey wire that comes off the turbo timer which connects to a 'shift lock unit' which is for japan only. Now seeing my car is a full import do i have to connect this shift lock unit in order to get the key out? If so where is it located? And just to add, coming off the plug n play adapter is a grey wire do i have to connect this wire to the 'shift lock unit' sensor on the turbo timer? |
Rice Killer
Im guessing yes, if the directions say so...do it.
i had that on my sil80. there is a wire that stops the key coming out. its connected to the igination. i cant remeber which wire it was as it was a long time ago sorry about that
#4 | |
sleeping in traffic
wat i have noticed is that just above the key release button, there is a little red button and that when it stays out you can't take the key out. Hard to get to because it's kinda covered by the steering colum casing. |
